04-18-2013, 04:05 AM | #1 |
5 speed or 6 speed.
Hello all. I'm the proud owner of an 87 Lwb half ton 4x4. Original trans and diffs. My question is: is there a bolt in 5 or 6 speed tranny that will work with the original 208 tc. Or even a 205. I've got a 4 speed with the granny. Don't quite remember the step from 1-2 being so big when I was a kid. But she's a doozy and I'd like a smoother trans and better milage.
Any advice would be much appreciated. Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device |
04-18-2013, 04:56 AM | #2 |
Re: 5 speed or 6 speed.
I have had both in my c10 (T5 & T56) but neither will work with 4wd.
04-18-2013, 06:04 AM | #3 |
I think the Getrag 5 speed that comes in the 88-up truck is a bolt in, but not 100%. Have to do some searching, it has been covered before. On CK5 too.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
04-18-2013, 07:34 AM | #4 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
04-18-2013, 09:51 AM | #5 |
04-18-2013, 12:29 PM | #6 |
Don't start off in 1st...?
1982 GMC C1500 4x4 w/ 305 and sm465. 2002 Kawasaki Ninja 250. 2007 Dodge Nitro. |
04-18-2013, 12:37 PM | #7 | |
Windy Corner of a Dirty Street
Here is a link to one of my NV4500 swaps that would be very close to what you are looking at doing.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
04-18-2013, 04:21 PM | #8 |
I haven't used the granny for anything but hauling. Just the gate from 1-2 and the high rpms at 65. I'm just looking for reliability for working and drivability on the highway. I'm doing a body off next summer. Going to find the right stuff befor she's tore down to make reassembly faster. This ole girl will be the last truck I buy. I want to set it up right the first time. Ill do some hunting for a nv4500. Is that a cast iron case or aluminum?
04-18-2013, 06:17 PM | #9 |
4500 is all iron, and heavy as hell!!!
04-18-2013, 06:19 PM | #10 |
4500 has aluminum bellhousing, top cover, and tailhousing. Main case is cast iron.
And like b454rat said, she heavy. I think it's around 220#.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
04-19-2013, 12:26 AM | #11 |
I can vouch for that. Wrestling one in by yourself is no fun.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF |
04-19-2013, 01:13 AM | #12 |
This will all be done when the body is off to paint next summer. Lol. I'm not a very big guy. The feed back is AWSOME on this site. Been a chevy guy my whole life. Can't thank y'all enough.
04-18-2013, 06:38 PM | #13 |
Ok, almost all iron....
04-18-2013, 08:15 PM | #15 |
It's got airplane gears in it. 3:73s or shorter. My 3/4 ton had 4:10s. Tires are 265-75-16's. stock rims. 383 stroker,eldo 600. The truck is all stock but the motor. I'm not getting the torque out of the motor because of the gears and trans. I'd like to keep it a manual. But would like and overdrive and switch to a 4:10 front and rear.
04-18-2013, 08:43 PM | #16 |
Not a real big diff going from 3.73 to 4.10s. Look in glovebox or under the hood for the PRO codes. Some came with 3.42s. but probly has less than that...
04-18-2013, 09:50 PM | #17 |
3500's make good boat anchors. Use the 4500 and it will last almost forever.
BTW 1/2 tons could come with everything under the sun depending on year...2.56, 2.73, 3.07, 3.08, 3.42, 3.73 and 4.10. Id keep the 4-speed if I had 3.08 and taller. but since you want to go to 4.10's, change away. Just remember not to lug in 5th and you will never have a problem. Of course this comes from a guy that use to stoplight race a stock 78, 350, 4-speed, 3.07's and 4x4. Put the truck in the low side (which divides your gearing in half) and open front hubs and this makes the rearend just like having 6.14's. The local racer guys could never figure out how i could beat them all day long and still run a buck 30 down the interstate. |
04-18-2013, 11:25 PM | #18 |
I have found i dont use first in any manual vehicle i own or drive whether it be my cavalier or my cummins the first is always way too low i use 2nd or 3rd depending on the situation and i would opt for a t56. Rsgear sells the adapter to make them 4wd for a cheap 1500$ or you could build your own for like maybe 100$
I tow in od in my cummins but then again that is probably built more for towing than other stated trannys and i also have to because i cant tow in 5th unless i wanted to max out at 45mph but if there is a hill obviously i may have to downshift depending on the grade
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
04-19-2013, 12:08 PM | #19 | |
Moderator
The 3500 is a good transmission if you stay within its limitations. Don't exceed 300 ft lbs or tow extremely heavy loads and it'll be just fine. The NV3500 is relatively light, fairly easy to find, and cheap. It's a geared for fuel economy... 4 useable forward gears with OD (5th). The NV4500 is difficult to find, big $, and heavier than a dead horse. It's not exactly an economy transmission being a 3 speed with LOW (1st) and OD (5th). I've done this swap on my '76. If I had it to do again I'd use a Gear Vendors OD on an SM465. I like my NV4500 and it gets me bragging points but from a purely functional point of view the SM465 with an OD box is way better.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
04-19-2013, 06:34 PM | #20 | |
Just my .02
04-20-2013, 01:37 PM | #21 | |
Moderator
I think my first NV4500 5th gear spline, on the tranny I put in my 76, was already shot when I bought it. 5th worked till I towed with it. No popping out of gear and no noises that my GMC hasn't made for 110,000 miles. I got a gutwrenching bang and thump on the flats around Jamestown NY and it was all gone. Kind of a sinking feeling when a $950 transmission and months of my time takes a dump on its' first road trip. I've towed with the GMC in 5th but only on the flats when I'm up to speed. I downshift for hills etc. I've run her for 110K.
04-19-2013, 07:05 PM | #22 |
Forgive my ignorance. But what I'm hearing is there is a bolt on OD for a 465? I know the sm465 is bullet proof. The only thing it's missing is an OD. Of I can bolt one on I'd be tickled to grins.
04-19-2013, 09:11 PM | #23 | |
For $3095 you can bolt this thing on the back of your existing transfercase and have OD. http://www.gearvendors.com/4x4gmmanual.html
04-20-2013, 12:48 AM | #24 |
Has anyone used it? Looks too good to be true aside from the price. Is it as tuff as the tranny it's going on?
04-20-2013, 08:17 AM | #25 |
there are guys over in the diesel word that use them all the time. but i looked into getting one out of a volvo and then geting the right adp. but gv wanted 650 for it with a core. the only other thing i was thinking is a brownie box. under direct and overdrive. for every gear.
other then that it looks like i am going with a clack vo or soome sort of spicer
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
