04-18-2013, 01:36 PM | #1 |
Easiest way to remove 83 rearend?
I don't have any experience working on leafspring rearends, just my 68 coil spring rear end. I doing a frame off resto of my 68 longbed and I bought a front end and rear end off my brother's 83 he is junking for $250. Only problem is, it is setting at the back of my dad's 10 acres. The front end is the same as taking off the one on my 68; I've done that. But whats the quickest way to get just the rear end? I'm going use my coil spring set up so I just need the rear end itself. Cordless saw-zall is a must I'm sure.
Can anyone give me some ideas what I'm getting myself in to or a quick way to drop it out of there? |
04-18-2013, 05:19 PM | #2 |
Re: Easiest way to remove 83 rearend?
Tow it back to a shop with some tools
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
04-18-2013, 05:31 PM | #3 |
Cluster King
I am not a huge fan of saw-zall or square body trucks so take plenty of blades, a spare battery and a medium size hammer and cut it out. 4 u-bolts, drive shaft, e-brake cables and brake hose. That is all there is to it. Take a 7/16 for the u joint straps if you don't want to cut the shaft.
04-18-2013, 06:13 PM | #4 |
Thanks...that's what I was looking for. As far as dragging the truck up to the shop, I have no way to put it back without wheels on it.
Thanks guys Posted via Mobile Device |
