Basic Tools Needed for Rust Repair?
What the basic list of tools needed for patch panel repair? What type of grinder is recommended for removing paint? What's best for making cuts in the sheet metal?
Thanks! |
Re: Basic Tools Needed for Rust Repair?
Cuts it sheet metal or cutting out rust I use a 4 inch grinder with a zip cut 1/8 or thinner blade, a mig welder is best but I settled for a flux core welder when weeding new pieces in, for removing paint around 80 grit removes it quick with flex pad on grinder with flexible metal oxide pads. This should get you started, check out my build thread I had to deal with enough rust.
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride |
Thanks!
