Old 07-31-2013, 02:59 PM   #1
Chance72
Chance72's Avatar
1986 with 327 problem
Ok guys, weve been messing with the carb and timing on my 86. Weve got it close to acceptable but we noticed that the fan was blowing the air out the front of the truck and not towards the block. Were thinking its the belt setup, do any of you guys have a diagram or something that shows the belt setup the right way on a 327?
1963 Longbed Stepside All Original (Sold)
1994 HUGE Lifted Two Door Blazer (Sold)
1972 Short Step 305 with 3 speed auto (Sold)
1965 C10 Short Step 327 with 350 turbo trans (Sold)
1986 GMC Short Fleet 327 with 350 turbo trans
Chance72 is offline   Reply With Quote
Old 07-31-2013, 03:03 PM   #2
79Betty
79Betty's Avatar
Re: 1986 with 327 problem
Is it a marine motor, out of a boat?
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 07-31-2013, 03:12 PM   #3
Kurt L
Kurt L's Avatar
if you have a serpintine belt system then you might have your water pump running backwards. does it run hot or warmer then usual? if so then your belt is runninng your water pump the wrong way. to reverse direction on your belt to make it run it at temp.
Kurt L is offline   Reply With Quote
Old 07-31-2013, 05:11 PM   #4
Chance72
Chance72's Avatar
Not a marine motor and it runs extremely hot. I drove it 3 minutes down the road and it overheated.
Old 07-31-2013, 05:13 PM   #5
chevylover2013
chevylover2013's Avatar
Weird! I heard of electric fans having backwards wiring, but never clutch fans.
Help!!!! My Chevy has a Ford stuck in it's intake manifold!
chevylover2013 is offline   Reply With Quote
Old 07-31-2013, 06:02 PM   #6
beamn7
What type of belt drive are you using? V belts or serpentine? Direct drive fan or clutch fan? Fan blade mounted backwards on clutch? (seen it done...........) Take a couple pics and post them....
beamn7 is offline   Reply With Quote
Old 07-31-2013, 06:09 PM   #7
chevylover2013
"Fan blade mounted backwards on clutch?"
What I was thinking, but wasn't sure it was possible.
Old 07-31-2013, 09:33 PM   #8
Chance72
Chance72's Avatar
Ill have to take some pictures tomorrow. Trucks at a buddy of mine... Fans not backwards as of what i seen the other day
Old 08-02-2013, 10:52 PM   #9
Chance72
Chance72's Avatar
Alright. I went over and checked out the truck. The serpentine belt is on right as we think. We took a closer look at the fan and it does seem to be backwards... Oops on the PO. Tomorrow im heading over to fix that problem then im gonna test it out! Got my title in my name today and im gonna go get it inspected soon!
Old 08-03-2013, 12:47 AM   #10
chevylover2013
Cool Beans! Now I know it is possible! Live and learn!
Old 08-03-2013, 10:53 AM   #11
LONGHAIR
Physically turning the fan around does not change the direction of the airflow. It is the rotation direction that matters.....look at the ceiling fan in your house.
If you have the serpentine belt system that turns the water pump in reverse and the older fan and water pump.....2 problems. Not only is the fan pushing instead of pulling, it is probably not doing it as well as it should, if it is the wrong one....but the water pump may be wrong too.
Everything has to match it's rotation direction.....CW or CCW
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 08-03-2013, 09:01 PM   #12
izzy_Britton
izzy_Britton's Avatar
+1
I was thinking this exact thing as i was reading the above posts. turning a fan around doesnt change anything in respect to direction of air flow. as LongHair motioned you could have a miss-matched pump vs. fan issue. with a little more research you might be able to figure out if the water pump is off a different year/model motor or if the fan is perhaps the wrong application?
going electric is a great idea but can get expensive quickly. just a thought.
-Izzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
Old 08-03-2013, 12:16 PM   #13
BONUSCAB
If you flip the fan around, it's gonna prolly destroy itself. And wreck a whole lot of stuff when it does. And could kill you if you are near it.
BONUSCAB is offline   Reply With Quote
Old 08-03-2013, 07:26 PM   #14
Chance72
Chance72's Avatar
Well guys after today and all the searching, Crosbys auto places don't seem to have any fans that are opposite to what mine is. Ive decided im going to change and go with dual 14 inch electric fans. Just tired of roaming around for nothing. The fan its self is what isn't right. The blades are angled the wrong way, I checked out my buddys 85 and more of the chevy trucks he has and all the fans are the direct opposite of what mine is. All run the same direction but the angles are different than what my blades are. So electric fans are coming in Aug 6 so ill just have to see from then.
Old 08-03-2013, 08:55 PM   #15
LONGHAIR
Don't ignore the water pump...it has to turn the right direction too.
Old 08-03-2013, 09:10 PM   #16
Chance72
Chance72's Avatar
Yea we checked it out. It seems to be from a yard or something.. How would I check to see if its turning the right way? Ive always said in my head on the belt, Smooth the smooth and "rough" to "rough". But I don't know if that is right. The belt is set right to how ive always said. But I might be thinking wrong?
Old 08-03-2013, 10:00 PM   #17
izzy_Britton
If you posted a photo we might be able to weigh in on the situation...
Old 08-06-2013, 07:26 PM   #18
beamn7
Pics would certainly help. Serpentine set up should use a reverse flow pump, V belt uses a standard flow pump.
As for the fan, I work for an OEM and we had sent out a tech bulletin to the dlr's about mounting the fan backwards when replacing the clutch so yes, it can be done... I didn't believe it either... Had techs doing it by accident....
Get those pics. I'm sure between all of us you can get her running cool!
"Longhair" is right, pump and fan have to match either clockwise or counter-clockwise....
