08-30-2013, 10:53 PM | #1 |
patch pannels
ive been looking at brothers.... im guessing i can use a floor pan from a 65 c10 truck for my 65 suburban? also what about the wheel arches from a fleet side? do "you" recommend using their cheap floor pan or the high dollar? im also looking to purchase rockers as well... anything i should consider while replacing rockers or floor? thanks in advance
08-31-2013, 06:49 PM | #2 |
1961 crewcab
Re: patch pannels
check out my build, I have some good pics of the floor (build is in my signature) the pass. side floor is different on a sub where there is a step to access the rear seat.
I was able to use truck rockers, they are the same... there is a steel plate that is factory that is welded to the rocker and rear quarter panel. short fleet wheel arch should work, but might require a little fab where the lip is welded to the inner panel on the sub (truck has no inner panel) if needed I think the truck pieces will work on the pass floor, it just won't be "correct"
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
09-01-2013, 01:04 AM | #3 |
60-66 Nut
Re: patch pannels
If you need to replace the outter floor/inner rocker, I recommend getting this piece versus the 2 seperate pieces. This makes it easier to keep things straight.
http://www.topbananaparts.com/driver...r-section.html The passenger side could likely be modified to be correct for a Suburban/Panel
09-02-2013, 08:14 PM | #4 |
Re: patch pannels
I'm new to all this.... Think I'm going to get those rockers captinfab thanks guys.... I'm going to check out your build.
09-30-2013, 08:13 AM | #5 |
Re: patch pannels
http://www.topbananaparts.com/driver...ker-panel.html for the outer? And this for the inner
http://www.topbananaparts.com/passen...r-section.html Posted via Mobile Device |
10-01-2013, 01:39 AM | #6 |
60-66 Nut
Re: patch pannels
Yes those are what I would use.
10-01-2013, 06:27 AM | #7 |
Re: patch pannels
thanks captain...
