09-09-2013, 04:04 PM | #1 |
Actuator Rod Concern
Hey all,
Have a 1991 S15 Jimmy with the extremely common loose tilt steering wheel issue. Found a bunch of articles on how to fix and have since tightened the 4 reverse torx bolts with thread locker so I never have to do this again...I hope. My issue is putting it back together. I noticed that the actuator rod can move back like six inches from the normal position close to the steering column and can also turn. Is this normal or did I just create more work for myself and broke the actual ignition switch? Also if I didn't damage it, I can't figure out how the heck it actually gets pushed down. Any guidance on this would be appreciated. Going to take some pictures tonight and post them to clarify things when I get home (at lunch currently) Thanks, Pat |
09-09-2013, 10:06 PM | #2 |
Re: Actuator Rod Concern
Ok, so here's some pictures. I'm not sure if the actuator rod even attaches to anything or not. It got pulled out during one of my "attempts" to remove the piece in front of the knuckle.
First is what I believe is normal position or what I think it is supposed to be. I don't see that it is hooked to anything and thought it was supposed to be attached to the actuator rack so when you turn the key, it moves the actuator rod back and forth. Next is what it looked like after I pulled it out (removed pivot pins of course, this is after I was trying to put it back together). Don't think that is normal Final is after I turn the key, it moves out but doesn't go back. Not sure how this is happening as I don't see it attached to anything. Worried that the starter wouldn't shut off like this. So any help is appreciated Thanks, Pat Last edited by Spline64; 09-09-2013 at 10:18 PM. |
09-09-2013, 10:55 PM | #3 |
Or is that for the high beams and I detached from the actuator when the rail fell out?
09-09-2013, 11:20 PM | #4 |
laying low
That may be better addressed over in the S10/S15 forum.
http://67-72chevytrucks.com/vboard/f...play.php?f=130
09-10-2013, 06:31 AM | #5 |
That rod is for the headlight dimmer switch.
In the illustration at this link the rod is part 67 It should be installed in switch part 68 part 14 pushes on it from the top to activate the dimmer http://www.s10planet.com/forum/attac...achmentid=2276 In the photo that is seventh up from the bottom at this sight the part that is labeled “plastic part in position” is the same part as part 14 from the illustration in the first link. http://www.fieros.de/en/articles/steering.html
For those of you that are wondering why you are not getting replies to your thread: Did you give the model, year, engine, fuel system type, and transmission information? If it is modified from what came stock from the factory, let us know that too. |
09-10-2013, 11:11 AM | #6 |
Thanks Chevy Tech!
That handles the dimmer switch. Last thing I need to connect is the switch acutator rack (47) to Actuator Assy, Ignition Switch (48). The rack fell out when I was removing the steering column housing. Is it possible that this (48) can fall into the column as I didn't see it (but wasn't looking for it either)? That diagram helps so much, really appreciate it!!! Thanks, Pat |
