Old 12-06-2013, 12:45 AM   #1
72c10suburban
72c10suburban's Avatar
'72 Suburban - 2005 L59 5.3/4L60 swap
Well, I bit the bullet today and picked up a 2005 L59 and 4L60 out of a Suburban. Complete drop out with 84,000 miles. Pretty sure I got the entire front harness since it has airbag sensors and turnsignals. It was complete with fuse box, air box and MAF, computer, Fuel pump, collectors with o2 sensors, DBW tac module and pedal. Lots of goodies and nice and complete for $1600, which i feel was fair.
Is this for the Flex Fuel?
72c10suburban is offline   Reply With Quote
Old 12-06-2013, 03:20 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: '72 Suburban - 2005 L59 5.3/4L60 swap
Looks like you got a decent deal for how complete it looks. Just make sure its a 2wd tranny, and you'll have pretty much everything you need to get started (as far as stock parts are concerned).
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-06-2013, 03:34 AM   #3
72c10suburban
Yep, its 2wd. A little more than i wanted to pay, but was the most complete deal i could find with fairly low miles.
Old 12-06-2013, 12:15 PM   #4
ls1nova71
ls1nova71's Avatar
Looks like you got a flex fuel sensor too. Are you going to try to keep it flex fuel? Not worth the hassle in my opinion but thought I'd ask. Good luck with the project!
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-06-2013, 05:53 PM   #5
72c10suburban
na. the sensor is already in the spare pile. i havent seen e85 in my part of the woods yet anyway.
got the engine cleaned a little and the harness off. it took longer to get the two plugs off the tranny near the shifter than the rest of the harness combined. I've decided to save a buck and do the harness myself. hopefully it wont be too bad.
Old 12-11-2013, 04:15 AM   #6
72c10suburban
I've made a little progress. Still waiting on some engine parts to come in, so I started on the harness. It wasn't too bad so far. The harness is stripped so now i have to round up a fuse box and relays and get them wired in and recover the harness. I used the pinouts from LT1swap.com, but had issues when it came to the C2 underhood, as the pinout on the site is from a 99 i believe and mine is a 05. I ended up checking continuity on all of the pink wires to find out where they went in the C2 plug.
The offending harness finally removed. I had trouble getting two of the tranny plugs undone. Once i got them out, it looks like they had been glued in at some point.
Starting on the PCM plugs
The C2 plug.
This is what all i removed.
And this is whats left.
I started a little tear down to replace some of the seals and clean it up.
Old 12-13-2013, 09:08 PM   #7
72c10suburban
finally got some parts coming in. The cam arrived along with the lunati spring kit. I also ordered comp pushrods, arp manifold bolts, and trick flow spring tool.
i got the tbss manifolds from GMPP and the engine plates are ebay specials. The intake rubber boots were supposed to be all black, so i'm trying to work that out with the seller. i can deal with the red filter, but not a fan of the red elbow.
Old 12-15-2013, 06:21 PM   #8
72c10suburban
hmm... back up lights. Where do i need to tie in to those at?
Cleaned up the engine and used the Chrysler balancer puller from O'reillys (67005) to pull the balancer. The two rods that it includes are too short for the chevy application, so i used the balancer bolt to start it, then switched to a 24mm 1/2" socket to pull it the rest of the way off.
Old 12-15-2013, 10:10 PM   #9
socaljess
socaljess's Avatar
looking good man.... that wire harness would make me dizzy lol
project 66 flat n low
socaljess is offline   Reply With Quote
Old 12-15-2013, 11:09 PM   #10
ivorton74
ivorton74's Avatar
Kool dawg...will be followin this build...just keep us updated
ivorton74 is offline   Reply With Quote
Old 12-16-2013, 12:03 AM   #11
whitels1
whitels1's Avatar
Hell of a start, looking good!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 12-16-2013, 08:04 AM   #12
Andy4639
Old member
Andy4639's Avatar
Wink Re: '72 Suburban - 2005 L59 5.3/4L60 swap
Looking good so far man.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-16-2013, 11:15 AM   #13
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
looks like you got a handle on it!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 12-16-2013, 01:12 PM   #14
Hart_Rod
Hart_Rod's Avatar
Nice project. What diameter is the air intake tube? Do you have a part number for the air cleaner kit?
Hart_Rod is offline   Reply With Quote
Old 12-16-2013, 09:56 PM   #15
72c10suburban
Thanks, its slowly starting to come togerther.
The intake is a ebay special. $57 shipped. I figure if it wont work, i can always resale it. Its a 4" tube.
Ebay air intake
The parts for my fuse box and OBD2 plug came in today. I'm going to build on the fuse box how to on LT1swap.com and just add 4 circuits.
Old 12-16-2013, 11:18 PM   #16
Hart_Rod
Hart_Rod's Avatar
Ebay air intake
Thanks!
Old 12-21-2013, 07:16 PM   #17
Average Joe
Average Joe's Avatar
Looks like progress. Nice work!
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 12-28-2013, 10:53 PM   #18
72c10suburban
Finally getting a little done now that the holidays are over. Got the cam and springs in today and got all of the aluminum vatted and some of it bead blasted. hopefully tomorrow ill have the engine sealed back up.
Old 03-23-2014, 07:18 PM   #19
solidaxel
solidaxel's Avatar
Ebay air intake
When I looked up your ebay site they want 399 for there kit?
Where did you find the 57 dollar one?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-25-2014, 09:43 PM   #20
desertdogg
desertdogg's Avatar
I found it down on the bottom try this link
http://www.ebay.com/itm/00-01-02-03-...3D390608038206
Trying to get thru my LS swap
desertdogg is offline   Reply With Quote
Old 03-26-2014, 09:23 AM   #21
solidaxel
solidaxel's Avatar
[QUOTE=desertdogg;6594848]I found it down on the bottom try this link
Thanks, found it, for that price I just wonder how good the air filter is, but I guess for that price you could use a K&N,
Did you ask them if they had them in Black?
LS 3 4L70E
Old 12-29-2013, 05:05 AM   #22
littlevictories
throw some new knock sensors in there while you got it apart, atmo
thats the thing been echoed by every guy i talk to IRL thats been playin with these motors for a minute says
looks good. you move fast, thats the way to be.
littlevictories is offline   Reply With Quote
Old 12-29-2013, 12:53 PM   #23
whitels1
whitels1's Avatar
Nice work!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 01-02-2014, 12:39 AM   #24
72c10suburban
littlevictories - Already in the works on new knock sensors. one was pretty rusted up, and i managed to chip the plug on the other one...
Finally got the engine sealed up.
And my homemade balancer installer. I used a piece of 16mmx2.0 all thread about 10 inches long, a couple nuts, a couple 1/2" pipe nipples and 2 3/4" washers.
Old 01-25-2014, 11:44 PM   #25
72c10suburban
