01-19-2014, 12:24 PM | #1 |
Is this a flip kit?
01-19-2014, 12:55 PM | #2 |
67-72 parts collector,…
Re: Is this a flip kit?
Not exactly.
Somone welded on a second set of "axle saddles" to your rearend. I assume they are welded?
01-19-2014, 01:04 PM | #3 |
that would be what the leafs are sitting on? And is that o.k.?
01-19-2014, 01:24 PM | #4 |
they welded another perch on there. its allot cheaper if you have a capable welder that you are confident can handle 3/16", i did it on my buddies truck, assembled everything then set the pinion angle.
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
01-19-2014, 03:02 PM | #5 |
Ok so basically it was a cheap way out to lowering the back. It does hit kind of hard but I guess that's the way it is. I'm going to run 22"soon so I'm assuming it will ride even harder? Should I leave it alone or put money aside for some other set up?
I don't know to much about mechanics so thanks in advance Last edited by markiemark; 01-19-2014 at 03:26 PM. |
01-19-2014, 09:01 PM | #6 | |
The "hard hit" is from lack of suspension travel. You may need a C notch in the frame to get some of that back without the bang. Cutting the original saddles off may help too.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
01-19-2014, 06:17 PM | #7 |
Watch out for your cornhole !
To add to what Keith said, that is a flip, but not done with a kit. The axle has been flipped which got you 5-6 inches of drop, but the person used a little different stuff than if you bought a commercially made "flip kit".
It gave the same amount of drop and does the same thing, just looks a bit different. I did the exact same thing on my 78 stepside. I call it the Poor Boy Flip Kit or the 13 dollar drop. I spent 13 dollars rather than 75 by doing it myself.
01-19-2014, 06:27 PM | #8 |
doing a flip kit this way is 100 times better than using the u bracket you can buy.
i'd call it the smart boy flip not the poor boy flip.
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
01-19-2014, 07:53 PM | #9 | |
You just have to make sure the driveshaft is not too long after the flip. Aftermarket flip kits move the rearend back (away from the trans.),... so the original driveshaft length will work,... AND to center the rear wheels in the wheel opening of the bedside.
01-19-2014, 08:03 PM | #10 |
That's how I have mine done but haven't welded it yet as I want to find out how much the kits move the axle back first so I can drill the perches beforehand. 2"?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
01-19-2014, 08:13 PM | #11 | |
01-19-2014, 09:55 PM | #12 |
Thanks for all the responses. From my understanding the truck has been done for a few years already. Once I have the bigger rims on I can think about a c notch. Is that something very involved or fairly simple. And it seems my set up will work just fine
01-19-2014, 09:57 PM | #13 |
Also my truck looks lower than 6" or maybe not....it's low.. that's all I know
01-19-2014, 10:13 PM | #14 |
Judging by the nuts and bolts rough the bottom of the frame, as well as the welds near the outside corner of the bottom of the frame, it looks like you already have a c notch.
01-19-2014, 10:48 PM | #15 |
That's good to know. So basically it's safe to say that I should just leave it alone ?
01-21-2014, 02:26 AM | #16 |
i would leave it, some flip kits have a problem with a little slop but if that is welded on, its not moving.
01-21-2014, 12:11 PM | #17 |
Happy to be here
You have a group of very knowledgeable guys offering great advice here. Help us out by posting more pics. We can see what you do and dont have.
01-21-2014, 12:55 PM | #18 |
I will definitely crawl underneath and take a few more pictures. Any angles in particular? Can't today because snowing like crazy but by tomorrow or Thursday I can get some.
Yes, very knowledgeable people hear that can help this amateur out!!! |
01-21-2014, 01:57 PM | #19 |
I'm just glad to be here!
Best view fo the C notch is from behing the wheel looking at the frame from the side.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
