Camaro Club
88 silverado suburban
Just got home from picking up my new-to-me 1988 Suburban. I found it on craigslist about 20 miles from home. Offered the guy my Honda 400ex and he was very interested so i loaded it up and took it for him to see in person. The plans are to use my 78 4x4 as a doner. The suburban will get converted to half ton 4x4 with parts from the doner truck. Im not sure if i will keep the 454 in the burb or put my 350 in it. It will also get the 4 speed and 205 transfer case from the donor truck.
Camaro Club
Re: 88 silverado suburban
Started driving the suburban to work this week. I wanted to enjoy it as is for a while untill i get time to tear into it. I still cant believe i found a solid suburban in ohio. I'm an automotive painter so i am used to seeing what ohio winters can do to a vehicle.
Camaro Club
Im getting ready to start the 4x4 conversion soon. I have found a ton of info on swapping over the spring hangers but unfortunatly very few pictures. Has anyone here done the swap and documented it with pictures?
#4 | |
1987 GMC R2500 SC 454 T400 1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors |
I have never done a 2wd to 4wd conversion, but years ago we went the other way and turned a 4wd K5 into a 2wd (the K5 was missing ALL of it's drivetrain anyway, nothing but a body left). The 2wd front crossmember bolt holes were already in the 4wd frame. The main things that I found were different are: the transmission hump is higher and has the access door on the 4wd, the rear leaf spring hangers are different to provide more lift on the 4wd, and of course the front leaf spring hanger hardware will be missing on your 2wd. You could always pull measurements off of your donor truck. It doesn't get any easier than these old Chevy trucks, the 4wd location holes are probably already there in the 2wd frame.
Camaro Club
It doesnt seem like anyone has been following this so hopefully some progress will help.
While i wait for some garage space to clear up i decided to do some little things to add some personal style to the suburban ![]() |
Camaro Club
I paint for a living so i just took some leftover clearcoat from another project and tinted it with black basecoat. Ive been using this method of tinting lenses for about 10 years
Camaro Club
Camaro Club
http://67-72chevytrucks.com/vboard/s...d.php?t=338556
Here is a link to my other truck that I'm stealing parts from for my suburban. |
Camaro Club
Camaro Club
i will keep the 14 bolt out of the suburban so if i ever come across some 8 lug wheels and tires that i like i can swap it back in and change the front 10 bolt over to 8 lug. But for now it will become half ton so i can use the wheels and tires i already have.
Second Chance Program
Subscribed.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
Camaro Club
Cool burb. Are you going to keep the mechanical clutch linkage or go hydraulic? What gears do you have in both sets of axles?
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
#15 |
Camaro Club
Going to stick with the Mechanical clutch. I'm trying to use as many parts from the donor as I can for the swap. I'm not sure what gears are in the either axle but i have taken the 78 on a few long trips and it cruises about 25-2700 rpms on the highway staying with traffic(speedo only works when slowing down)
#16 |
Camaro Club
#17 |
Camaro Club
#18 |
Camaro Club
#19 |
Camaro Club
#20 |
Camaro Club
#21 |
I like your Suburban and your plans for it. Keep us updated as you work on it. I grew up with these Suburbans and really enjoyed them. Thanks for sharing your build.
C@rnut001 (Owen) Alaskan Members Check In http://67-72chevytrucks.com/vboard/s...22#post5094422 http://67-72chevytrucks.com/vboard/s...18#post6778618 |
#22 |
Camaro Club
double post. oops
#23 |
Camaro Club
#24 |
Camaro Club
this suburban is so clean i can still read the chalk markings on the body panels and frame.
#25 |
![]() Join Date: Feb 2014
I just saw this thread so I will offer my two cents worth. Back in 1995 I converted an 86 C20 to K10 using parts from K5 Blazer. The easy part to start with is the front core support brackets. The 4wd brackets use most of the same rivet holes as the 2wd ones. I lined up what holes I could and then drilled out the frame for the remaining holes necessary. I used grade 8 bolts in place of the rivets. That gives you a square starting point. I would measure the donor truck's frame for the location of the rear hanger brackets.
Since you are converting to 4x4 and using a manual trans, there will be some work required for the hump to accommodate those parts. On my current 86 k10, while doing a cab swap, I cut the hump out of the old cab and made a bolt in cover for the new cab. Just another point to consider, the exhaust on the passenger side will need to be reworked to accommodate the transfer case. Good luck and I look forward to your progress.
86 Chevrolet K10 350/SM465 Frankie SOLD 1995 GMC Yukon GT SOLD 1996 GMC Yukon GT 2010 Suburban 1500 4x4 5.3l/6L80e. Sold 2016 Silverado 2500HD Crew Cab 4x4 6.0l/6L80e |
