Old 05-15-2014, 10:54 AM   #1
ronniehotdog
ronniehotdog's Avatar
My first 1965 c10 bag build----------fast and cheap build
My first 1965 c10 bag build------------------------
My plan is to bag the front and rear. I want it to lay the frame.
383 tpi stroker.
I have built many tube chassis rock crawl rigs but I want to be driving the truck soon so I'm going the cheap and not so right way. Raise the crossmember up 2.50" forward 1"
ronniehotdog is offline   Reply With Quote
Old 05-15-2014, 10:58 AM   #2
Ta2Don
Ta2Don's Avatar
Re: My first 1965 c10 bag build----------fast and cheap build
I'm in for the ride...
aboard!!! We like lots of pics, Hint, Hint...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 05-15-2014, 10:59 AM   #3
ronniehotdog
Cutting the front out starting in.
1983 front parts found.
Old 05-15-2014, 11:56 AM   #4
ronniehotdog
Getting ready to cut the dish in for the front 2600's
Old 05-15-2014, 12:00 PM   #5
ronniehotdog
Got the frame cut up 2.5 and forward 1.
Crossmember fits good.
Old 05-15-2014, 12:16 PM   #6
ronniehotdog
Need to clean the back shop out.
Old 05-15-2014, 12:26 PM   #7
BADAZ chevy guy
BADAZ chevy guy's Avatar
Welcome to the forum!
Keep us posted on the build.
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182
700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236
BADAZ chevy guy is offline   Reply With Quote
Old 05-15-2014, 01:02 PM   #8
1963c-10
1963c-10's Avatar
Welcome and nice start on the project!!
1964 Short bed trailer
Old 05-15-2014, 04:04 PM   #9
rusty76
rusty76's Avatar
I'll ride.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 05-15-2014, 06:37 PM   #10
Bomp
Bomp's Avatar
Watchin.
Bomp is offline   Reply With Quote
Old 05-15-2014, 08:28 PM   #11
jhama78
jhama78's Avatar
Rock buggies eh? In thanks for the chance.... Lol
-j-rod
'06 3500 LWB CC 4wd, 8.1 Allison
jhama78 is offline   Reply With Quote
Old 05-15-2014, 09:36 PM   #12
jdmsevenstar
jdmsevenstar's Avatar
I’m curious does that front "c notch" of the forward crossmember work??? i have seen the sandwich technique and of course the famous drop member but i have not seen this technique used. What else needs to be modified besides the cutting of the frame??
overspecialize and you breed in weakness...
jdmsevenstar is offline   Reply With Quote
Old 05-16-2014, 02:31 PM   #13
aggie91
I'm just glad to be here!
aggie91's Avatar
Great start Ronnie. Welcome to the board!
This has been done before a few times that I know of. I did it on the '82 I built for my son, I only did 1.5" up and no forward movement. I used No Limit's Rack & Pinion conversion for the steering upgrade and used PBFab's lower Forward Arms. Rob (No Limit) did it on their project JT (there is a thread on it in the 67-72 section). There is also another member, theastronaut, that did the same 1.5" up on his truck he is building.
This is much easier then doing the pancake or sectioning of the crossmember itself. If you do not do the rack & pinion conversion, then the steer components will need to be relocated the same dimensions as well.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-16-2014, 09:15 PM   #14
Chapstr's65
Chapstr's65's Avatar
I'm in
-Chapa
65 SWB step-side / 383 stroker / TH350 / 4:10 gears / static drop 4 1/2" front 5" rear.
Chapstr's65 is offline   Reply With Quote
Old 05-15-2014, 10:33 PM   #15
Jeff La
Well I follow along all the time, so I'm here
Jeff La is offline   Reply With Quote
Old 05-16-2014, 01:04 AM   #16
Captainfab
60-66 Nut
You're not wasting any time.
Looks like someone massaged that firewall a little. It must have had a big block in it at some time.
Old 05-16-2014, 01:54 AM   #17
ronniehotdog
I think the firewall is stock. It had a straight six when I got it.
Old 05-18-2014, 12:46 AM   #18
Captainfab
60-66 Nut
No, it has been beat on at some time to make room for a nonstock engine.
Old 05-17-2014, 12:16 AM   #19
ronniehotdog
To go sledding tomorrow or work on the truck?
Old 05-17-2014, 12:17 AM   #20
ronniehotdog
Got the arms started
Old 05-17-2014, 12:19 AM   #21
ronniehotdog
Rear is cut and ready for a new frame
Old 05-17-2014, 09:25 AM   #22
BigSky71
LAIDOUT
BigSky71's Avatar
Fast start! What rack and pinion do you intend to use?
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 05-17-2014, 11:28 AM   #23
ronniehotdog
stock steering just raised up and moved forward. I am new to the whole 2 wheel drive thing so I will do what I know will work.
Old 05-17-2014, 01:16 PM   #24
creep
Registered Loser
creep's Avatar
Nice! I like the low buck, home builds. Lots of good ideas and fab work.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 05-17-2014, 08:36 PM   #25
ronniehotdog
Got the a arms done
