05-16-2014, 09:51 AM | #1 |
c20 towing capacity
Still trying to nail down the towing capacity of my c20. I want to pull a small toy hauler. Few hundred pounds short of 5000lbs loaded. I included pictures of the receiver and where the hitch bolts to the frame. Any opinions?
05-16-2014, 10:38 AM | #2 |
Re: c20 towing capacity
Disc, or drum brakes?
05-16-2014, 10:51 AM | #3 |
05-16-2014, 12:17 PM | #4 |
Look at the metal tag inside the drivers' door and it should tell you the MGVWR - that is your max combined vehicle+trailer towing number. Are you saying your combo (incl truck) is 5000 lb or the trailer itself is 5000 lb loaded?
05-16-2014, 01:43 PM | #5 |
The GVR rating on the metal tag really doesn't reflect the actual capability of the truck. depending on the overall condition of the vehicle & trailer skill of the driver road conditions ect. there isn't any definite answer. I see 3/4 ton trucks with a gooseneck trailer hauling large backhoes bulldozers and trailer loads of livestock past my corner every week. and its steep narrow curvy roads. those trucks are most times grossing in excess of 20,000 pounds. What im stating is there isn't a really definite answer to the question.
05-16-2014, 01:46 PM | #6 |
good point - I don't disagree with you. I TRY to not exceed the MGVWR in most cases, but it is a limited capability. Mods can increase the capacity.
05-16-2014, 03:42 PM | #7 |
The 67-72 trucks don't have a vehicle posted Combined Gross Vehicle Weight (rating) limit covering both the truck, cargo and any trailer. But in any event the trucks GVW and Max Axle ratings should not be exceeded. See the service manual or driver's handbook for load information. Drum brakes are not the best for towing in SoCal especially the grades on the 5 or 15. In fact the gearing going up is going to keep you running slow and stressing your cooling system. Need to consider the measured weight of the trailer, truck and all the cargo as a whole.
But there are factory publications showing "recommemned" equipment and loadings. This table is from the 69 RV brochure and outlines equipment and gearing to tow with. The load data is from the 70 service manual (last two years of front drums). While GM I hesitate to post the table in fear of it being taken out of context by someone who sees a number without using common sense. In no way would I recommend that a SWB C10 haul a 5000lb+ trailer at 70 mph during a Sunday night get home rush that happens every weekend here. But since it is factory and a "recommendation" it would do well to temper any towing decision with their posted data. Remember these were for new, well maintained trucks. Age, wear and maintance short comings will show up at the worst possible moment. AAA + RV is a really good idea. In your specific case it is important to note that whole setup is a modification of a step bumper and is not the sort of equalizer hitch GM recommended. If it were me I'd keep that at or below 2500lb max based on what you posted up. While it may very well go more, it has very little in the way of a torque box and basically just hangs off the tail of the frame. If you want to haul a toybox of any size I would recommend at least an inspection by a custom hitch maunfacturer (not just a kit bolt on shop). Pretty certain they would agree with me that a true receiver hitch that runs up the frame and a spring load equalizer will make a safer freeway hauler. Remember here the winds can add a lot of side load and destabilize a trailer very quickly. If you have coils a set of airbags and premium shocks will help a lot too. Coils just don't have the inherent friction stabilzation leafs do.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
05-16-2014, 04:17 PM | #8 |
good info Tim, thanks - so the GVWR on the plate is just the max for the truck (and its load) all by itself, yes? Excellent references posted above.
05-16-2014, 04:52 PM | #9 |
Yes, As an example here is a simplified beakout using rounded, assumed weights.
If you had 4.57gears and a 350 in your truck, 11,000lb is the recommended limit for everything combined or GCW. Based on a 11,000lb GCW, Truck 5000lb (front and rear axle weights combined) add to that, Hitch load 750lb measured trailer hitch loading weight (adds to truck cargo weight). The truck now weighs 5750lb. Note, This is well under the possible 7500lb max or GVW (front plus rear axle as weighed at the ground). To that we add, Trailer 5000lb (weighed at the trailer axles) So now our Combined Weight is, 10750lb or just below the max recommended GCW. That means we can still add a little more, 250lb cargo Or basically you, your dog and a cooler! :-) The four important LOADED weights to remember here. Combined Gross Weight (recommended by GM) Front axle weight (max posted on the data plate) Rear axle weight (max posted on the data plate) Trailer axle weights (limited by the traile mfg) Finally the max load on your data plates is for a truck equipped with the springs and tires to carry it, most were not. The "as built" number should be used unless you know the springs and or tires are capable of the max load within axle limits. As a point in case, just last fall I found a really nice C30 dually with a max GVW of 10,000lb but it had be ordered light thus carried a 6,600lb "as built" rating!
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 05-16-2014 at 05:05 PM. |
05-16-2014, 06:19 PM | #10 |
Paying attention to weight ratings is like paying attention to how many tylenol you should take for a headache. I always take four to get rid of the headache quickly. Most people only take two because that's what the label says. Your pickup can handle way more than they recommend.
05-16-2014, 09:49 PM | #11 |
Got it hooked up. Dragged it about 30 miles so far. Half freeway half surface street. Didnt have a problem. Tomorrow I plan on taking it about 85 miles total. I included pics.
I am worried now that one post says to stay under 3000lbs. Its 3400 dry. Two sport quads 1 dirt bike and other stuff probably brings my total weight for the trailer to 4700 lbs tops. it crused right along on the freeway. I checked the hitch under the truck and nothing is lose. All the welds look good. am I crazy to tow this rig? paul |
05-18-2014, 02:32 AM | #12 | |
I'm not a towing expert but that setup looks more the reasonable for that pickup. Nice truck by the way!! |
05-18-2014, 03:40 PM | #13 | |
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
05-16-2014, 10:26 PM | #14 |
Well you wanted the information so I gave you the offical numbers.
Your hitch is a receiver tube attached to a regular step bumper. http://67-72chevytrucks.com/vboard/s...d.php?t=628163 While they added a crossbar and extended to the lower frame flange the fact is it all just hangs a good distance off the rear of the frame. So it really is more of a deadweight hitch that a weight distribution style/equalizer hitch. All the load is spread over a very short frame length. The spring bars are very good to have and help to reduce the tongue load on the rear axle by adding a twisting upload at the hitch. Problem is the very parts its trying to twist is the hitch in question. As toyboxes go your is small and should not have too much of a problem. However I would suggest actually weighing the loaded trailer so you don't have to use the word probably. Most scales don't charge if they are slow and you don't need a printout.
05-16-2014, 10:47 PM | #15 |
Thanks for the info. Glad you express your opinion. Dont worry if you think its something i dont want to hear. Sounds like you all know a hell of a lot more than i do. Up to now i have never towed anything more than a couple jet skiis. Maybe 2000lbs total. Im going to continue to look into ways to strengthen the setup.
So what is recommend then to boost my towing capacity at the hitch that would make it a safer setup? paul |
05-16-2014, 11:11 PM | #16 |
Godspeed sir. Don't underestimate the capabilities of your pickup.
05-18-2014, 06:29 PM | #17 | |
Your step bumper was originally attached to the frame with the two "S" shaped side bars and the four closely spaced bolts. That works pretty good and most I have even found a rating for were about 2500/250Lb. On yours they added a lot but most of it is to keep the bumper itself from folding up and really does not address the frame loads. While you pointed out it has foru additional bolts, they go into the lower flange and are not even supported fully where they contact the frame. As it sits your hitch is very much like a spring board if that helps you picture the loads. As far as making it better, there may be ways and as I suggested earlier a good shop might be your best start. You stated in you other thread a coulpe of shops agreed it would be ok for a 5,000lb trailer. But I must ask did you tell them it was an equalizer rig or did they offer to "certify" it for you as a paid service? My views became very strong on the subject of hitches and mirrors due to hauling a lot of horses in and around California. Live loads are a true test of a vehicle system as a whole. You should experience having a pair of quarter horses who are swaying in unison inside a trailer just for the fun of it. In fact on my prime truck we did not even run a rear bumper. Just had a receiver hitch and the frame exposed so they could be inspected easily, along with the spare. Since you admitted to being new to this, a review of "Trailer Life" trailering guides might give you a lot of background, verbage and some reassurance. http://www.trailerlife.com/trailer-towing-guides/
05-18-2014, 08:26 PM | #18 | |
ill post what I find out. |
05-19-2014, 01:52 PM | #19 |
I went this morning to orange trailer and hitch. The owner looked at my hitch and said 5000lbs is no problem. He said it would be advisable to use a weight distribution system which I am using.
This was the second opinion from a trailer and hitch installer. I think im done worrying about this. Thanks to all for their input. paul |
05-16-2014, 11:14 PM | #20 |
An old 3/4 ton can do a lot.
05-16-2014, 11:25 PM | #21 |
A brand new chevy 3/4 ton? 35k? 40? Thats what their going for in calif. Smogged, computerized, and over priced!
I love my 1970 c20! I get so many complements everywhere I drive it. What year is that? My dad used to have one of those! People just love my truck. And so do I! paul |
05-17-2014, 12:34 AM | #22 |
I built it
my thinking is the manufactures underrate whatever they make to stay out of lawsuits from the people that dont know how to handle a load safely. just underrate it to the point that most people wont get in trouble.. and the ones that do get in trouble tow or haul something totally unsafe anyway.
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
05-17-2014, 12:42 AM | #23 |
The trailer with the camper looks to be evenly balanced over the trailer axle. If soYou need to put some weight in the bed of your truck. that trailer will push the rear end sideways if there is not sufficient weight on the rear tires. That's why a gooseneck hitch is great.it plants the trailer weight in the center of the bed. As a rule of thumb the truck needs to be 25% heavier than whatever its towing with a bumper pull trailer.
05-17-2014, 12:54 AM | #24 | |
I am going to put a lot of stuff in the truck bed: beer, ice, gas, guns, ammo, fire wood, inflatable sex dolls, meth lab starter kit, you know the basics. |
05-17-2014, 01:15 AM | #25 | |
there very easy to hook up to and pull much better & safer than a bumper pull. I have two gooseneck trailers . one is a 30 ft stock trailer and the other is a 24 ft flat bed. I pull them with a 3/4 71 chev big block 402 or a 78 3/4 with a 454. My brakes work on my gooseneck trailers however I rarely ever turn them on. |
