Old 06-24-2014, 01:10 AM   #1
'68 Newtricks
'68 Newtricks's Avatar
4L65 trans cooler adapter sizes
Looking to trade my factory hard lines for some braided AN lines. I've got these two sizes pulled up from Summit Racing. These seem to be the two sizes I've read about.
Not sure if they are metric or NPS
Out of a 2005 Yukon XL, 4L65e
http://www.summitracing.com/parts/rus-640520
http://www.summitracing.com/parts/rus-670520
Anyone know which size the trans uses?
Thanks all
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 06-24-2014, 12:26 PM   #2
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: 4L65 trans cooler adapter sizes
I used the first one listed with the 1/4 NPS in my 4L60E trans. I am pretty sure that the 4L65e case did not change that port.
I ran -6 braided line all the way to the cooler mounted in front. I used a factory HD cooler that used the same fittings on it to adapt the AN line to it. Worked out great.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 06-24-2014, 12:44 PM   #3
'68 Newtricks
I found the second fittings on another website that specified them as 4L65 adapters.
So I'm all confused cause I've read exactly what you've typed from others too
'68 C10 SWB
'85 K30 Blazer
Old 06-24-2014, 01:46 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
My 80e used the straight 0-ring fittings as well (but the 80e has a specialized fitting set).
The th350 up through the EARLY 90's 80e's all used the 1/4 NPSM o-ring fittings, literally every trans. If you look at the stock part, its the PTC with a 1/4 NPSM on the other side.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-24-2014, 02:55 PM   #5
'68 Newtricks
Ok
What I'll do then is just order both and send whatever doesn't work back. I hope it's the second link since they are cheaper
I'll report back the results.
'68 C10 SWB
'85 K30 Blazer
Old 06-24-2014, 03:00 PM   #6
aggie91
aggie91's Avatar
I looked at a few transmission sites and there seems to be some conflicting info out there. Bowler and TCI show them to be the same, but a couple of others show different part numbers for each trans, but no specs on what threads they are.
Karl
The LST Challenge:
Old 06-24-2014, 04:23 PM   #7
wgeyer88
Check out this link:
http://www.sweetperformance.com/prod...product_id=480
Will
1970 CST10 SWB LQ4/4L80E
2004 Silverado (sold)
2007.5 Dodge Ram 2500
wgeyer88 is offline   Reply With Quote
Old 06-24-2014, 06:46 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Bowler is right, because....Bowler.
Old 06-24-2014, 07:02 PM   #9
clinebarger
Starting on 11-29-07 the cooler line fittings changed to 9/16-18 thread, Before 11-29-07 the fittings are 1/4" NPSM on ALL 4L60E, 4L65E, & 4L70E, NO confusion, This is from a GM TSB.
clinebarger is offline   Reply With Quote
Old 06-24-2014, 10:54 PM   #10
solidaxel
solidaxel's Avatar
Thanks, that just confirmed my question on a 2003 4l65E
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
