07-12-2014, 01:00 PM | #1 |
project low buck dump truck with a diesel twist
I picked up a 73 one ton dump truck a couple months ago. I have almost 8 acres and need to haul rock and fire wood. So far I have hauled about 23 ton of rock and many other things. Well on the last load the clutch died on me. So instead of just doing a clutch it is getting an engine swap, cab swap and a paint job. I know I will get flamed but the new power plant is going to be a c 350 olds diesel with a turbo. Keeping the 4 speed manual with a new clutch. If the 350 dies later I have a 455 out of 71 toronado that I will put in. I'm on a tight budget so I'm using stuff I have laying around.
07-12-2014, 01:11 PM | #2 |
Re: project low buck dump truck with a diesel twist
Here are some pics of the truck I'm starting with and new cab.
07-12-2014, 01:15 PM | #3 |
The diesel 350 goodwrench engine I have to put in. This is another truck I picked up. I was going to use the frame and flat bed off it but the frame was worse then the one on the dump truck. So I am just using the bed off it.
07-12-2014, 01:28 PM | #4 | |
Cool. Not into diesels but I am into low buck. What's with the gas can and battery? Did you run the engine sitting on the ground?
07-12-2014, 01:43 PM | #5 |
Ya it had been sitting in my shed for about 5 years so I wanted to make sure it wasn't stuck or anything. It ran good.
07-12-2014, 01:48 PM | #6 |
Here is the frame without the cab. I'm going to fix some rust and I might box the rear to help with the heavy loads.
07-12-2014, 02:50 PM | #7 |
I clicked on this and thought oh awesome then noticed you were even from iowa that's just awesome
Rust is better than rice. |
07-13-2014, 02:18 PM | #8 |
I got the engine pulled apart last night. I'm putting new head gaskets and arp studs in it to be safe. It looks really good inside. It still has the cross hatches in the cylinders. Also installing a new timing chain while it's apart.
07-19-2014, 12:50 AM | #9 |
Its like christmas here. lol. I got some parts in the mail today. Yesterday I did some welding on the frame, hopefully it will be ready for paint in a few days. I'll put some pictures up tomorrow.
Brent |
07-23-2014, 01:22 AM | #10 |
Here are some pics of my progress. Frame is welded up and engine is ready to go in.
07-23-2014, 03:25 AM | #11 |
What kind of turbo are you going to be using on the 350 diesel?
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
07-23-2014, 12:25 PM | #12 |
I have a Garrett t3 t4 hybrid I was going to try first. If it is too small I have a John deer tractor turbo to I can use
07-23-2014, 12:37 PM | #13 |
Alright I'm along for this one! I LOVE low buck builds!
Current Build 89 s10 ecsb 2wd 4.3/700r4 50k OG Miles Instagram- shaggin_s10 '86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt (Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD |
07-24-2014, 12:05 AM | #14 |
I got some more parts today. Rust free doors that are basically brand new and have never been installed. Hopefully tomorrow should be a productive day.
Brent |
07-24-2014, 08:53 AM | #15 |
I love low buck and I love throwing turbos on things that never had them. Go Iowa!
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
07-24-2014, 09:16 PM | #16 |
I checked your thread out and I dig the green truck. If you get up around my way and want shoot the **** let me know. I got the doors on today. I have a 83 Hurst I need to get painted for a customer so I'm talking a few days off from the dump truck.
07-25-2014, 08:50 AM | #17 |
Right on man. I'll hopefully get up to Cedar Falls racetrack here before the end of the season, but that will probably be as close as I get. I've got to get gears for Green Jeans before I do though. Dang highway gears...
