07-31-2014, 11:37 PM | #1 |
Will 1987-1991 blazer fuel tank work?
Anyone on here try using a stock efi tank from a 1987-1991 chevy or gmc Blazer/jimmy on any Ls swap? Can you please share your experience or post pics with this tank?!
I'm building a 72 chevy k5 blazer, Ly6, 700r4 Bowtie stage ll, np205 I read that GM made these tanks with internal baffles to keep the fuel from sloshing etc.. I also see I can swap a walbro 255 internal pump into the stock sending unit pump location?!! I don't need any fuel issues while I'm miles deep in the Back country Elk Hunting Thanks
1949 Chevrolet 5 window 1970 C10 CST swb, fleet side 1964 C10 swb, bbw 1968 Camaro coupe 1968 camaro convertible (cream puff) 1972 K10 swb 4wd SuperCheyenne |
08-01-2014, 01:14 AM | #2 |
Re: Will 1987-1991 blazer fuel tank work?
I'm interested in this for future reference as well. Seems plausible unless there are differences in the rails/cross-members on the newer blazer from the 72. Of course those can be modified.
Kirk 72 Blazer CST 4wd highlander 66 Nova Last edited by Blazerowner; 08-01-2014 at 01:58 AM. |
08-01-2014, 02:06 AM | #3 |
Second Chance Program
Thats what all us square body boys do!
Yes, 87-91 blazer/burb tansk work perfect. They do have the internal pump and baffling. To work with the LS all you have to do is drop in an EP381 acdelco fuel pump (or equivelant) which is physically exactly the same as the 87-91 low pressure pumps, but is a high pressure unit. Its out of something like a 97 one ton chevy truck. So thats it! 87-91 tank, EP381 pump, done!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
08-01-2014, 07:30 AM | #4 |
I perfomed this install on my 1987 square body c10 a few years back and i had many miles of trouble free driving. confirmed. the ep381 fuel pump performed flawlessly.
08-02-2014, 12:39 AM | #5 |
Enjoying left field
I believe they are the right width, but I think you have to move a crossmember.
08-02-2014, 12:59 AM | #6 |
AWESOME!!! I will take the time to cut some metal or relocate a x-member/bracket or whatever to just have a 31 gallon, efi baffled fuel tank in my Blazer!! Thanks fellas
08-02-2014, 08:36 PM | #7 |
Enjoying left field
Personally, I don't like the big tanks. Thats 300 pounds and $130 hanging back there.
08-02-2014, 10:11 PM | #8 |
The tank I used in my 84 K10 came from my LS swapped 81 K5 it does not have baffles, I used an 03 silverado fuel pump module which has the bucket that acts like a baffle, a vette works tank ring, and have not had any issues in the rocks, sand dues etc in 110deg heat. Here is a video of the swap into the K10 when it was all said and done I welded a piece of angle in the rear cross member.
08-02-2014, 10:13 PM | #9 |
Freakin Awesome!
I'm using an '87 tank and sending unit in my '72. I put a Walbro 400 in it though.
I haven't had a chance to mount the tank yet but I looks like it should fit.
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee |
08-03-2014, 03:34 PM | #10 |
I figure the 31 gal tank will benefit me because Elk hunting is a 250 mile trip one way! With that being said I guess it would be a PIA to get over the mountain passes with that much weight in back plus towing a flatbed aluminizer with 2 atvs also?!
01-19-2015, 11:13 PM | #11 |
08-04-2014, 12:10 AM | #12 |
08-04-2014, 08:43 AM | #13 | |
Looks Good though, thanks for sharing pics!!
08-04-2014, 11:14 AM | #14 | |
Freakin Awesome!
08-05-2014, 09:20 AM | #15 |
Awesome thanks!!
06-23-2017, 02:19 PM | #16 |
For anyone else looking into this the 92-96 31 gallon tank appears to be identical except the filler neck is on the opposite side but doesn't have the 90 bend on it.
03-02-2018, 12:51 PM | #17 | |
Filler neck hole is on the correct side for the first gen k5. I need a tank in mine and would like to go ahead and get a bigger one that would work for a further LS swap but could also work for now with my stock 72 motor and fuel pump. Anyone know if I can buy the stock 96 fuel pump/sending unit then pull the fuel pump out and replace it with a piece of fuel line. Rely on the 72 fuel pump then, to suck from the new tank just like it does with the older set up. That way I could go back to the in the tank pump when I do a LS swap later?
1972 K5 Blazer 350/350/PS/PB From GA but live in Panama City, FL |
08-06-2014, 11:05 PM | #18 | |
08-05-2014, 11:48 AM | #19 |
Am I correct that there were two sizes of Blazer tanks? I had two in storage and installed the smaller of the two into a '63 SWB. I used a door in the fender from a square body truck for filler access.
I still have the larger tank but I thought it might be out of a Suburban. Was there a difference? Any dimensions handy?
08-05-2014, 03:23 PM | #20 | |
Freakin Awesome!
08-06-2014, 11:56 PM | #21 |
Seems like this swap is a no brainer if you are going fuel injected. It's funny I have never seen anyone do it before.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
08-07-2014, 03:33 AM | #22 |
This is the same tank I purchased for my LS swap. I have only read one other thread where someone used this tank. It's definitely more cost effective then most options out there. I picked up the tank from classic industries for $89 and a sending unit off of rock auto for $59
08-07-2014, 09:48 AM | #23 |
^^^what did you guys do for a filler neck??
08-07-2014, 07:40 PM | #24 |
10-05-2014, 11:55 PM | #25 |
I plan on using this tank for my lq4 swap. How do I connect braided fuel line to the sending unit? Will hose clamps work or is there a fitting to convert to an style?
1971 blazer 4x4 Awaiting lsx/4l80e swap |
