08-06-2014, 11:21 PM | #1 |
Frame lengths
Hey everyone I'm new to the site,
I picked up a1963 chev suburban. Just wonder if the frame from the suburban Is the same length as a swb or lwb. From what I measured seems to be Swb. Thanks in advance. I'm also trying to Post picture but not having luck. |
08-07-2014, 01:41 AM | #2 |
Re: Frame lengths
115wb, should have that info on the blue trim tag in cab on drivers panel by the vent
08-07-2014, 03:08 AM | #3 |
Re: Frame lengths
Yeah I'm pretty sure that the swb is the same as the c10 burb/panel. 115" wheelbase.
Not to hijack the thread but a quick simi related frame question. Is there a difference between the 1/2 ton and 1 ton frames? Not suspension but frame itself. I'm a little concerned now that I found a 1/2 ton frame from a 63 P/U under my 60 1 ton panel. It does have the 1 ton suspension but I'm curios to know if there was a physical difference between the actual frames |
08-07-2014, 04:18 PM | #4 | |
Re: Frame lengths
there is also a difference between the dimensions of the frame rails as show in the following link http://67-72chevytrucks.com/vboard/s...d.php?t=550856 ron |
08-07-2014, 05:54 AM | #5 |
65 suburban vortec 5.3 bagged
Re: Frame lengths
I used a long bed frame and cut it down to the 115" short bed length and used it on my suburban and it worked without any problems. reason was I had already modified my truck frame with air ride stuff and a new cross member so it was easier to swap it than start over. it is on my build thread with pictures.
08-07-2014, 07:29 AM | #6 |
Re: Frame lengths
The wheelbase is the same. Although the back part from the wheel to the rear bumper is slightly longer of about 4" to 6". I can measure it after work later today if you'd like.
"El Jerry" '03 3500 Duramax dually '96 1500 ext. cab Chevy '66 swb C-10 '63 Panel '60 VW vert '56 VW vert |
08-07-2014, 11:18 AM | #7 |
Re: Frame lengths
Thanks for your reply, Chakah it's all good
No need to measure thanks again. |
