08-10-2014, 11:57 PM | #1 |
Small block pass. car clutch fork - what's it fit?
This came out of a 275HP 327 I bought last year - engine's a '67, was supposedly in a '64 Impala most recently, but repro examples of a '64 Impala clutch fork don't look like this one. The only identical example I can find is described as a '65-68 Impala/Biscayne/Bel Air piece, but I can only find one. Any help?
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
08-11-2014, 01:53 AM | #2 |
Re: Small block pass. car clutch fork - what's it fit?
gm sometimes makes a part only for a few months then they come up with something diff i guess you could say kinda like old skool recall i have come across it 2 times with camaro's one was 88 firebird with a one of a kind tranny mount $315.00 for a $10 mount they only put in the car for a few months the other was a clutch fork for mid 80's camaro dealer only part $200 for it only diff between that fork any other fork was position of nipple but made it worth $$$ i guess so chances are same with part you have
08-11-2014, 06:43 AM | #3 |
I didn't think exact application mattered with these,unless you are building a 100% correct vehicle. I mean,they all reach in to the same place from the same place to do the same thing. Am I wrong? I do always match type of bellhousing to the clutch fork "type" it originally went with.
08-11-2014, 01:41 PM | #4 | |
look at pic the tip is offset a bit some are centered and some have the pivot as much as 3 or 4 inches from the opening where the throw out goes |
08-12-2014, 07:10 AM | #5 |
I meant I go by the bell housing,not year,make,model. That's how I match things up knowing nothing about what vehicle they are from. Or take one from here and use it on bell housing from there..
