Old 08-21-2014, 11:36 PM   #1
jstrong394
jstrong394's Avatar
Ls accessories question
I didn't get the alternator ac or power steering setup when I got the 5.3 from the junk yard. The engine came out of a 03 burban. Will any of these work off of any 5.3 or do I need to look for specific ones? Also since in running carb'd will I need all aftermarket fuel system stuff? I have read through the forums but guess I can't figure out for sure what will work
jstrong394 is offline   Reply With Quote
Old 08-21-2014, 11:45 PM   #2
Root2812
Root2812's Avatar
Re: Ls accessories question
If you have the 5.3 crank pulley then you can use the accessories off of any 5.3 or 4.8 because they have the same spacing.
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 08-22-2014, 12:06 AM   #3
BigDan3131
BigDan3131's Avatar
The fuel system depends on how much power you want in the future and if you decided later on you want an aftermarket fuel injection system to go on your carb manifold. I would rather have to big of everything instead of everything too small. You can get a large fuel pump that can be used for either FI or Carb.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 08-22-2014, 12:15 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
You'll need all the aftermarket fuel stuff, but because carb is low pressure, its not the same kind of expense that we have with FI. You can use low pressure line, a low pressure (cheap) pump and cheap fuel filters ETC. if you want to go all-out and get high end stuff you can...but you can get away without it on the carb'd setups.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-22-2014, 12:37 AM   #5
jstrong394
jstrong394's Avatar
I do have the crank pulley. I guess I will end up going big on the fuel system I would hate to redo it if I get bored with the carb and decide to go fi
Old 08-22-2014, 01:45 AM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Well....you'll still have to if you go FI. The FI stuff is all high pressure, so lines, pumps, filters etc would have to be redone anyway.
Old 08-23-2014, 01:11 AM   #7
BigDan3131
BigDan3131's Avatar
Unless you using AN everything you wont.
Old 08-23-2014, 07:08 AM   #8
boostedc10
boostedc10's Avatar
Even if you run -8 feed and -6 return the only cost you are saving is in the line and a few fittings. Just like Br3w said you still have to replace the pump, filter, and regulator which is where things get expensive depending on your setup.
If you plan to carb the motor just plan to replace this stuff later and get the cheap stuff for now.
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 08-23-2014, 12:18 PM   #9
jstrong394
jstrong394's Avatar
Alright sounds like the wisest choice. Thanks for the replies
Old 08-23-2014, 05:42 PM   #10
Blackpony
Blackpony's Avatar
If you go witg an aeromotive regulator, all you will have to change later is the spring and diaphragm which they sell as a kit pretty cheap. Id suggest spending the extra money on an lines now, they are much nicer and durable not to mention you wont have to change them out later.
Blackpony is offline   Reply With Quote
Old 08-26-2014, 01:46 PM   #11
jstrong394
jstrong394's Avatar
On the accessories I will need brackets as well. Will I need to find them off of a car of will a truck or SUV work? I have read that cars are best, but I think that is for swaps into cars
