Old 09-03-2014, 02:31 AM   #1
kitsbeach
kitsbeach's Avatar
1967 No Frills LWB Fleet (now SWB)
Hey Guys, I thought I should start a proper build thread to track the progress on my truck as it moves along.
It’s a 1967 LWB Fleetside. It’s had only a few owners and is basically a survivor that seems like it has always been well maintained. It is running a 6 cylinder and four speed, but was originally a three on the tree truck.
I’ve started to do some work on it, which I will post here. But I will start with the original craigslist pictures.
EDIT:
I've finally cut my truck down to a short bed over the winter of 2021.
I've posted a picture in post #81 and will try to add some details of the process later.
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
kitsbeach is offline   Reply With Quote
Old 09-03-2014, 02:34 AM   #2
kitsbeach
kitsbeach's Avatar
Re: 1967 No Frills LWB Fleet (now SWB)
A few more craigslist pics
Kitsbeach (Ken)
Old 09-03-2014, 02:41 AM   #3
kitsbeach
kitsbeach's Avatar
I’m not going to go for a frame-off restoration but just kind of keep the survivor/shop truck vibe going. I will likely fix some of the rust but just patch the paint and keep the exterior as is. Plans are to do the following things over time:
1. return to the original three on the tree (done now)
2. clean up the interior to stock look with rubber carpets
3. new 15” steelies with dog dish caps
4. lower either a 4/6 or a 5.5/8 and make it handle
5. short bed conversion
6. long term an LS swap and a 6 speed manual trans
Couple of more pics after getting rid of the canopy.
Kitsbeach (Ken)
Old 09-03-2014, 02:44 AM   #4
kitsbeach
kitsbeach's Avatar
More pics
Kitsbeach (Ken)
Old 09-03-2014, 02:46 AM   #5
kitsbeach
kitsbeach's Avatar
I took out the four speed and went back to the three on the tree setup that the truck came with stock. I've only driven it around the block but love it already.
My truck is a 1967 but I picked up a Saginaw 343 out of a 1969 truck so that I could have syncro first gear. It seems much quieter than the four-speed Muncie 420 that was in it.
First I went around and collected all the parts I needed. I'm superstitious about the vehicles being off the road for too long. Plus I didn't want it hogging all the space in my garage.
It seems there are a few combinations of shift rods for these trucks (the rods that go from the steering column to the shift arms on the tranny). I needed 6 cylinder to Saginaw 3-speed arms.
My truck came with shift rods for the original Muncie 318 non-syncro 3-speed (pictured here) but hey don't fit (Muncie 318 is a lot shorter than the Saginaw 343). They are about 24" and 27" long in case anyone else is trying to tell one set of rods from another.
Kitsbeach (Ken)
Old 09-03-2014, 02:48 AM   #6
kitsbeach
kitsbeach's Avatar
The Saginaw 343 tranny I bought was behind a 307 V8 so they wouldn't fit either. This is them and they are about 22" and 27" long.
Kitsbeach (Ken)
Old 09-11-2014, 12:00 AM   #7
Saclandman
Saclandman's Avatar
Nice '67!
Rich J.
1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD
2002 Chevy Tahoe 4X4 5.3L SOLD
2015 Chevy Silverado Crew 4X4 5.3L
Saclandman is offline   Reply With Quote
Old 10-13-2014, 07:11 PM   #8
kitsbeach
kitsbeach's Avatar
I've got a few pictures on my iPhone so thought I should update this thread.
I patched up the hole in my floor late from where the 4-speed shifter was. I did it on a Sunday night and had to make do with what I could buy from Home Depot late at night, but it is patched up and will do for now
The hole was pretty ugly. Looks like it was a V8 high hump and someone had to cut it open a bit for the 6 cyl shifter location and they also did a pretty rough job of patching the hole.
Kitsbeach (Ken)
Old 10-13-2014, 07:24 PM   #9
kitsbeach
kitsbeach's Avatar
My patch was only a little bit better. The tin I found at Home Depot was a bit thin so I did a double layer with some polyurethane goop in between. Then pop riveted it all together.
I used this stuff called "backer rod" as a gasket for the high hump because I plan to have the hump off again one day for a tremec tranny upgrade.
And a little duct tape to finish it off and give it that professional look...
Kitsbeach (Ken)
Old 10-13-2014, 07:28 PM   #10
kitsbeach
kitsbeach's Avatar
Cleaned up the floor in preparation for some sound deadening and new rubber flooring.
My air vents are so full of pine needles even after vacuuming them out at least 3 or 4 times. Each time I take it for a drive I get a new wave of them.
I think this truck was parked under the same tree its entire life.
Kitsbeach (Ken)
Old 10-13-2014, 07:39 PM   #11
kitsbeach
kitsbeach's Avatar
There are a few ugly spots on this cab.
It has actually be repaired before and I can see new rockers welded in and some of the cab mounts. But the rockers are rusted again and one of the original cab mounts needs done soon. There is also a crude repair job on the floor under the gas pedal.
But I'm going to ignore all that for now. I'm planning a short bed conversion in 2015 and will possibly tackle rockers and cab mount then. But I want to keep the truck looking old and worn on the outside.
Anyway it cleaned up well with lots of soap and hot water and here I have started placing the sound deadener.
Those little white spots are more polyurethane I used to plug a bunch of extra holes that were in the floor. I think maybe it had a different set of seats in it at one time.
Kitsbeach (Ken)
Old 10-13-2014, 07:59 PM   #12
kitsbeach
kitsbeach's Avatar
Here's a couple shots of the sound deadener stuff I bought from Brothers as a kit. It came with the tar-backed strips and then the full size jute pad with the silver backing. I also bought the behind the seat kit and the door kit (which I will get to later).
I had luckily bought an extra roll of the jute silver stuff which was good because the kit didn't fit my high hump. And I used the extra to fill in the back corners and to patch a few problem spots.
Kitsbeach (Ken)
Old 10-13-2014, 08:06 PM   #13
kitsbeach
kitsbeach's Avatar
I used some black duct tape around the edges so the silver doesn't show behind my black rubber mats.
I possibly should have trimmed more off the edges of the silver jute stuff so I could have taped it to the floor easier. But, then again, the closer to the edge it is the quieter I hope.
I ended up painting the area under the seat black for now because I didn't want the silver stuff showing. I'm looking for a rubber or vinyl black floor covering for that area because the silver jute isn't very tough. Hartrod had a pic of a vinyl covering in his '68 that looked pretty good.
I'm just waiting for the black paint to dry so I can finish up the door sills and put the seat back in and have the truck drivable again.
Kitsbeach (Ken)
Old 10-13-2014, 08:17 PM   #14
kitsbeach
kitsbeach's Avatar
I also pulled the stock gas tank out from behind the seat. It wasn't hooked up and the truck has a saddle tank in it. That'll give me some room for stuff and later for a subwoofer and some of those corner speaker brackets bigblock73 makes.
I wanted to keep the stock filler neck and couldn't figure out what to do because I wanted some neck showing (like stock) and didn't like the idea that some guys do where they basically bolt the gas cap on flush to the grommet.
So I ended up cutting the filler neck off of the tank and just putting a nut and bolt through it so it won't come out. It could get pushed in if someone pushes hard enough but at least I'd know where to find it. It has a nice ridge on it preventing it from falling in by itself.
Later on I filled the neck with some of that foam sealer stuff so that nobody fills my cab with gas. it's pretty easy to do. I've almost done it myself.
Kitsbeach (Ken)
Old 10-13-2014, 08:19 PM   #15
kitsbeach
kitsbeach's Avatar
By the way I filled the tank with water while I sawed the filler cap off. I don't know how likely it is that a spark could blow the thing up but I'm pretty sure it can't blow up when it is full of water. Sawzall took it off in 3 seconds.
Kitsbeach (Ken)
Old 10-13-2014, 08:29 PM   #16
kitsbeach
kitsbeach's Avatar
The Brother's rubber mat wasn't a perfect fit. It doesn't line up for the seat bolts and the little holes for the "mushroom" pegs that keep it from slipping don't line up.
But the dimmer hole lined up well and I like the rubber itself. I wish it extended under the seat.
It says "69" on it and I wonder if it would fit a '69 better, but, from what I've heard, I doubt it.
It does fit the high hump very well and lined up under the dash nicely. Just one tiny spot near my '67 gas pedal where I could see the silver jute underneath so I covered it with a bit of black tape.
I'll post installed pics later once I get the sill plates in.
Kitsbeach (Ken)
Old 10-28-2014, 08:51 PM   #17
slowcpe
slowcpe's Avatar
Good looking truck. Of course I love the white grille and bumpers I actually liked the camper shell as well.
Also I like the filler neck idea, may steal that when I install the one under the bed. I love the look.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 10-28-2014, 09:49 PM   #18
kitsbeach
kitsbeach's Avatar
Thanks..!! It needs to get lower but I am slowly getting around to the 5-lug conversion and drop stuff.
Kitsbeach (Ken)
Old 01-07-2015, 02:42 AM   #19
kitsbeach
kitsbeach's Avatar
Just realized I haven't posted up any pictures lately.
Here is the only one I have of my new rubber carpets. I'll have to take some with the glove box back in.
I also took the ugly stereo out and need to get a radio delete plate.
Kitsbeach (Ken)
Old 01-07-2015, 03:00 AM   #20
kitsbeach
kitsbeach's Avatar
I also ripped the old farmer truck rear bumper off and installed a sport bumper. I got some of the correct ivory paint made up in rattle cans and painted it. Again I have no good pictures for some reason and will have to take some.
Kitsbeach (Ken)
Old 01-07-2015, 03:07 AM   #21
kitsbeach
kitsbeach's Avatar
And I put in the 5-lug conversion axles on the back. This was a really easy job and went real smooth. My phone was dead during the install so I didn't get any pics but I followed this video posted up by Tx_firefighter a while ago and it explained it pretty well.
My retaining bolt for the pin was a bit different and my spider gear bushings were a bit different but the idea is the same.
https://www.youtube.com/watch?v=WqdmUPWpI9c
Kitsbeach (Ken)
Old 01-07-2015, 03:11 AM   #22
kitsbeach
kitsbeach's Avatar
These rims are wheel vintiques 15x8 and I rattle canned them with the color-matched ivory paint.
I can't wait to get my front brake conversion and lowering done so the truck will sit how I want it.
Kitsbeach (Ken)
Old 01-07-2015, 03:20 AM   #23
kitsbeach
kitsbeach's Avatar
I got a set of dog dish caps off of ebay. They are not correct for the truck but they are easy to find and I think come from late 60's Novas and Camaros. Shawno72 had a set on his super cool patina'd 68.
Kitsbeach (Ken)
Old 03-01-2015, 09:29 PM   #24
kitsbeach
kitsbeach's Avatar
I haven't done much to the truck lately but I mounted the one 6-lug wheel I have on the front and took some pictures.
I've done the 5-lug axle conversion on the back and plan on doing the front disk brake conversion soon. Once it is a little lower I will buy some new tires for my steelies, but I want to get an idea of the size after I've dropped it down.
I did clean up my front bumper with a spray bomb. I liked the bit of "character" it had with the rusty scratches but it does look a lot cleaner painted.
Kitsbeach (Ken)
Old 03-02-2015, 02:36 PM   #25
kitsbeach
kitsbeach's Avatar
Also painted my air cleaner black as I assume that was the original colour.
Kitsbeach (Ken)
