10-22-2014, 09:30 PM | #1 |
Need more info guys
Had another forum member give me some info on a GMC suburban
he is thinking of selling and curious what the options were for static drop on the rear and how low I could get it with the leaf springs or can I convert to trailing arms with coils? what about swapping the body to a C10 chassis? |
10-22-2014, 09:46 PM | #2 |
Never Ending Projects
Re: Need more info guys
Basically the same applies to the burbs and panel that applies to trucks. Only difference is the rear drop might be a little lower then what is advertised for a truck (i.e. 4" drop for a truck might be closer to 5" on a burb/panel due to more weight in the rear).
As for a frame swap, the rear part of the frame is different. It steps down where a truck is straight. Also burbs/panels are setup for rear gas tank.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
10-22-2014, 09:55 PM | #3 |
So what are my options for lowering the rear using the leafs?
I have a 66 GMC that was 3/4 ton lon bed I swapped over to C10 shortbed chassis but still used the rear leafs and removed a couple leafs to lower a few inches... |
10-23-2014, 01:49 AM | #4 |
60-66 Nut
With leaf springs, you need to be careful how many leafs you remove or you will have bad axle wrap. You can also move the differential to above the springs, but this gives you a lot of drop.....around 5-6". A longer shackle will only lower the ride height about 1/2 as much as the increase in lengthen of the shackle.
If you want to convert to trailing arms and coils, just keep the original frame and install the necessary parts.
