10-23-2014, 12:17 PM | #1 |
Bagged C10s: QA-1 Shocks?
Hey guys! I'm looking at upgrading the damping on my C10. I've already driven on it for close to 15k miles. Now I want to take it up a notch. Occasional track use (LS Fest Autocross), maybe to drag strip before and after the twins are installed. But overall, just fun driving. Spirited driving. Cruising.
Anyone use the QA-1 shocks? My truck is bagged. Staying bagged. Want to explore these shocks for adjustability and toss ability. If not QA-1, what do you use? No-Limit? KYB? I have Z'd front, custom 4-link rear. Outboard trailing arms. Lays frame. Nearly stock height at full lift. Nice low ride height. Thanks!
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
10-23-2014, 07:09 PM | #2 |
Re: Bagged C10s: QA-1 Shocks?
I have QA-1 coil over single adj. shocks on my 50 pickup, really like them, much better that the old coils over set up before. This is for the front only, have leafs in the rear and haven't changed those yet...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
10-23-2014, 07:23 PM | #3 |
Interested in this thread as well. I have the KYBs that come with the Porterbuilt kit but thinking about swapping them out with the Ridetech HQ shocks. They are adjustable and come with great reviews.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
10-23-2014, 08:29 PM | #4 |
I've been thinking of upgrading from the kyb shocks to the Ridetech hq shocks, also.
///Relaxed Atmosphere |
05-05-2015, 10:18 AM | #5 |
05-05-2015, 10:24 AM | #6 |
Some general info here:
05-05-2015, 10:25 AM | #7 |
and some info on the difference between RQ and HQ
10-23-2014, 10:58 PM | #8 |
Ride Tech is the number 1 company for shock 'tunability' w/air suspensions. Check w/Chris @ Smittys!
10-24-2014, 07:12 AM | #9 |
Thank you everyone!
10-24-2014, 08:41 PM | #10 |
It'd be alot cooler if you did
I'm a big fan of the QA1's I installed on my car. The adjustability is sooo nice and I'm surprised how much the adjustments change ride characteristics.
10-24-2014, 09:37 PM | #11 |
Has anyone used the QA1's on a static dropped truck?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
10-25-2014, 10:41 PM | #12 |
Hart_Rod,
http://instagram.com/p/ulLRx_oDwq/ I imagine they'd be awesome. Dialed the rears in at 6 clicks and drove 40 miles. Wow! Gotta play with fronts tomorrow. Bought the DS502 and RS502. They are car porn.
10-25-2014, 10:43 PM | #13 |
Smashingchuck I totally agree. Amazing.
10-27-2014, 03:34 PM | #14 |
I have them on my static truck. I have Qa1 coilovers on the front and regular spring/qa1 rear. They are only 1 way adjustable but I like them I usually don't mess much with them but I softened them for a road trip and got them too soft. I adjusted them and got a great ride. I can adjust as needed.
Thanks Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
10-27-2014, 03:57 PM | #15 | ||
10-27-2014, 04:23 PM | #16 |
Sorry Rob I may not have been clear.
My front is converted to coil overs with Qa1. The rear uses the adjustable shocks but 4 inch drop "factory" style springs.
10-27-2014, 07:11 PM | #17 |
I have the same set-up, switch stock springs for coil-overs with QA1 shocks, much better ride and you can adjust the shock for ride. Haven't changed the rear shocks yet, but it's on my to do list...Jim
10-27-2014, 11:25 PM | #18 |
I got all four installed. Still bag suspension and QA-1 RS402 up front, QA-1 DS502 out back. Night and day difference. I tried it with the fronts at 0... I changed them to 6 clicks each. Same for rear. Perfect!
10-28-2014, 08:35 AM | #19 | |
10-28-2014, 05:27 PM | #20 | |
(1) what was available and in stock - I hate driving to Summit to buy something and have to wait any time for it #instantgratificationrequired. (2) what was adjustable, worked with my ride height, laid out height and has the proper compression and rebound at ride height. My DS and RS are both 18-way adjustable. The DS have the collars for the coilovers/spring setup. I assume the DS are coilovers and RS are just the slick shocks.
10-29-2014, 12:12 PM | #21 | |
http://www.ridetech.com/store/shocks/
10-29-2014, 12:19 PM | #22 | |
Here are the facts on QA-1 Street Star Shocks: http://www.qa1.net/suspension/street...ks/street-star Custom Mount Rebound Adjustable Smooth Body Shock Absorbers QA1’s Street Star shock gives you that smooth ride and smooth look for your vehicle. With a comfortable compression setting and 18 valving options of rebound adjustment, you are sure to find your preferred suspension setting. Bright Anodized Lightweight Aluminum Body Rebound Adjustable with Comfortable Fixed Compression Smooth Body 100% Dyno Test and Serialized Revalveable and Rebuildable by the QA1 Factory or QA1 Authorized Service Centers American Made Precision Machined Aluminum Piston with PTFE Piston Band 5/8” Centerless Ground, Hard Chrome Plated, Solid Piston Rod Three Step Sealing System NEW! QA1 has expanded its offering of Street Star rebound adjustable shocks to include eyelet mounts on both ends of the shock in 7”, 8” and 9” shock lengths.
10-28-2014, 11:57 AM | #23 |
What do you have for shock relocators up front? I think I want to run adjustable shocks too.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
10-28-2014, 05:19 PM | #24 |
I am using the stock locations for the front, CPP upper & lower control arms.
10-28-2014, 12:33 PM | #25 |
Just for reference..... what shocks were you running? Age?
Tags |
#dirtydianah, bagged, lsx, qa-1 |
