10-26-2014, 08:25 PM | #1 |
Front Indicator LED problem..
All my lights work great, I just put new bulbs in the cluster, new switch, and new grounds on the panel and signal housings- was having some issues but no more.
Now, all I want to do is put a LED 1157 bulb in the front housing for my blinker/park lights. As soon as I did, when I turn my lights on, the cluster indicators come on steady. The blinkers work but indicators are on steady when not blinking. I bought new non thermal flashers and still the same thing. Any advice? One flasher said electronic-from Oreillys, and the other said heavy duty and electronic from Autozone. Neither had 2. thx!! |
10-26-2014, 08:39 PM | #2 |
Re: Front Indicator LED problem..
I don't think there is a solution for the parking lights being led. Something about them grounding through the bulb.
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
10-26-2014, 09:01 PM | #3 |
Old member
Dennis,
To run the LED's you need the grounded blinkers.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
10-26-2014, 09:32 PM | #4 |
10-26-2014, 11:12 PM | #5 |
US Army Veteran
Small world. About three weeks ago, I added LEDs for the blinkers and had the very same problem. It was not easy getting the LED 1157's to seat, either.
Thought maybe it was just a bad set of LEDs, because they lit up in the cab when I turned the headlights on.
1972 C10 Highlander - The making of a daily driver |
10-27-2014, 01:32 AM | #6 |
Let me know if it works. I was under the impression that the parking lights would not function correctly. Every other bulb I have is led except those.
10-27-2014, 09:53 AM | #7 |
I ordered a pair of the flashers from summit. I'll try it and send 'em back if its a no go... I'll keep yall posted...
10-27-2014, 01:28 PM | #8 |
Old member
Mine work great. Dennis just ground it to anything close to the fuse panel. I used the park brake mount. I have LED's in everything in my 71 truck except for the headlights and fog lights.
10-27-2014, 01:51 PM | #9 | |
What about LEDs in the cab and cargo lights? Do the 2357s work fine in the rear lights to make them brighter?? thanks!!
71 LWB Large Bore 6-71 Blown 383 Stroker 4.11 Motive/EOM Eaton Posi Ported/Polished Carrier 15x8/15x16.5 MT Radials B&M Pro Shifter Truck Name- Spike |
10-27-2014, 02:55 PM | #10 |
Old member
I have a set of van lights inside so they are good and bright. I have the LED brake lights though.
10-27-2014, 03:48 PM | #11 |
Sweet ill order some LED 's for the front now
10-27-2014, 06:53 PM | #12 |
Old member
Here is a better shot of the LED parking/turn signals.
Read this also. The flashers got it straightened out for me. http://67-72chevytrucks.com/vboard/s....php?p=5393945
10-27-2014, 07:07 PM | #13 | |
10-27-2014, 07:13 PM | #14 | |
10-27-2014, 07:16 PM | #15 |
Old member
I would think so. They are on a seperate circuit. I used both flashers.
