WTB:Blazer exhuast bracket
As seen in the picture circled in red.
1972 cheverolet K5 CST Blazer 350/auto/AC/PS/PB/Aux Batt From Medford, Oregon |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: WTB:Blazer exhuast bracket
ttt
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
I think have have your bracket. I've been trying to get a good photo of it underneath the blazer but the photo doesn't come out. the body is still on the blazer so I dont' see an easy way to get to the top rivet on the frame yet. any ideas
Thanks |
A 90* drill start out with a 1/8" bit and step it up to 3/8" is the only way I have removed those rivets without damage to the bracket.
Use a die grinder to cut into the rivet head a couple times or more. Then just hammer and chisel the leftover pieces. Yank the bracket off. You just have to be careful with the grinder to not cut into the bracket so go slow when you get near the bracket. Busted at least a hundred this this way. By far the fastest method. I use an air hammer for the final busting.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
The reddish vertical part w/ the holes and bit of rubber is a cheap generic bit you can find in any parts store. Google exhaust hanger for pics.
![]() Join Date: Dec 2007
Is this it, I pulled this off my frame but it is hard to make it out in the picture, if offroden can get his let me know.
No that is not it. Thxs anyway Alex
Is this is the 1 you are looking for, from a 72 blazer 4x4. ( sitting on top of the cross member).....Ed
Yes that is it.
