LS1 not starting....less fuel pressure ?
Hy all
today it was time to get the engine firing up the first time after the swap. Unfortunately the engine is not running... The fuel pump is running ....also i do have a spark But i am not sure how much fuel pressure the injectors need for proper working ?? At the moment i dont have installed a fuel regulator....so the fuel just goes through the rails and back to the tank....dont know how much fuel pressure i do have ...... The engine does crank strong but there is not even a little firing.. Hope u can help me once again Thx Achim |
Re: LS1 not starting....less fuel pressure ?
I don't think that it will get any pressure to the injectors without a regulator.
1979 GMC Sierra Grande Crew Cab C25, 454/TH400/4.10-Project truck/ DD 1985 Chevy K5 Blazer 700r4/4.10/8 lug- in search of new engine 1993 GMC Sierra K1500 4L60E 2007 Suzuki Forenza- her DD and the family vehicle |
You will have no pressure (or at least nowhere near enough) without the regulator. You can try a bit of starting fluid to see if it will fire off, just don't get carried away with it.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
Hy again
in fact the fuel injectors need a specified amount of pressure for working.. I was able to press the return line together so i could reach a bit of fuel pressure...and immediately the engine fired up :-) So i am looking forward to install the fuel pressure regulator and hopefully everything is fine.. I keep u updated :-) CU Achim |
