Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 12-18-2014, 02:51 PM   #1
Gobuffalo
Gobuffalo's Avatar
The Bufmobl Build
It took 3 years to get here. There have been a lot of changes to this point. Some for quality sake, others because of money.
Finally got the body mounted to the frame and the doors and front end on. I waxed every painted surface before I assembled, took almost a whole tub of wax. Bought a nice cover, real soft on the inside. As soon as I got it on, the snow started. So now I'm in the garage doing all the little stuff like sand blasting, painting and zink plaiting door guts.
P.S. Do any of you need a custom built Suburban/Panel body cart. I'm done with the one I built for this and it's in the way. Check the for sale ads.
Gobuffalo is offline   Reply With Quote
Old 12-18-2014, 03:51 PM   #2
pwdcougar
pwdcougar's Avatar
Re: The Bufmobl Build
Love the color scheme. That's a great looking truck!
Did you do all the body work on the cart? I'd like to see pictures of it.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 12-18-2014, 04:27 PM   #3
Gobuffalo
Gobuffalo's Avatar
I did all of the sheet metal work on the rolling chassis. Then I moved to a rotisserie.
Old 12-18-2014, 04:39 PM   #4
Gobuffalo
Gobuffalo's Avatar
I wasn't sure exactly where to mount the rotisserie on the back. We ended up putting it on the inside and bolting and welding it to the lower part of th door jamb. One reason for the rotisserie was for sandblasting, primer and replacing the rear floor.
Old 12-18-2014, 04:46 PM   #5
Gobuffalo
Gobuffalo's Avatar
Then I put it on the cart for final fitting, primer, block sanding and paint.
Also, I was worried about getting overspray on the powder coated frame.
Old 12-18-2014, 04:55 PM   #6
Gobuffalo
Gobuffalo's Avatar
Found a side shot of the cart.
It supports the body at factory mounts 2, 4 and 5 on both sides.
I put a bunch of pictures in the ad.
Old 12-20-2014, 10:33 PM   #7
pwdcougar
pwdcougar's Avatar
That cart looks like a great idea. I'm rethinking how to go about body work and paint. I was going to remove the body from my donor truck, put it on the rotisserie for sandblasting and rough body work then onto the frame for final bodywork and paint. That isn't going to work because the engine already on the frame.
Paul
Old 12-21-2014, 09:55 PM   #8
pwdcougar
pwdcougar's Avatar
The pic from the rear on the rotisserie, is it bolted to the top side of the plywood floor? I appreciate (and have saved) all the pictures!
Paul
Old 12-22-2014, 10:07 AM   #9
pwdcougar
pwdcougar's Avatar
The plywood floor on the donor body is in great shape so I'll probably leave it in place unless there is a reason is should come out.
Paul
Old 01-13-2015, 03:24 AM   #10
Gobuffalo
Gobuffalo's Avatar
I'm Back!
After being married for 30 years, my wife decided we needed vacation to celebrate. Kauai is assume.
2 days before I left I was running a snow blower. Now I have to get used to shoes again.
But I digress.
While the body was in paint jail, I worked on the frame. Got it powder coated, installed a 6" lift from Off Road Design and put axles on.
Old 01-13-2015, 03:42 AM   #11
Gobuffalo
Gobuffalo's Avatar
I said it had been thru some changes.
The Dana 60 rear was fine with a small block. I decided I needed MORE POWER. So I built a 496. 550 lb.ft. of torque is awesome! Until you put on some new mudders and step on the right pedal. It will shear the axle flange right off the end of the shaft. When my wife asked "how did you do that" the only reply I could think of was "stepping on the gas".
That required a new axle or 2. Come to find out the 70's and 80's military GMC pickups (M1008 I think) have 14 bolt rears and Dana 60 fronts that bolt in with only changing the rear shock mounts. They come with 4:56 gears with a Detroit Locker in the rear and a posi in the front.
Old 01-13-2015, 03:51 AM   #12
Gobuffalo
Gobuffalo's Avatar
So now I've got way more engine then I will ever need and extra heavy duty axles so what is gonna go next. That's easy, the TH350. So out with old and in with the new TH400 and NP205. Now you get to move everything around so it will all fit. Now that it fits why not buy new drive lines because they don't fit anymore. Neither does the exhaust.
Now I'm glad I sent the boy to welding school.
Old 01-20-2015, 01:56 AM   #13
Gobuffalo
Gobuffalo's Avatar
After sitting in paint jail for more than a year, I told the painter I wanted it back ASAP. He told me if I wanted it back I had to come up with $9400.00 for labor and $2500.00 for materials. This was $9400.00 more than I owed him. I offered him $3500.00. He said no. So the Burb came home. Found another painter that quoted $3500.00, so I took it to him. I thought it came out very nice. Only time will tell.
In the mean time, my sister called me to tell me about an LQ4 and a 4L80E in a truck I could buy for $500.00. Needless to say, I bought it and installed it but that's in an LSx swap swap thread.
Here is a picture today with the front end and door handles on. Going to need all new glass as mine is all scratched and pitted. Need to find $1000.00 somewhere. That trip to Hawaii sucked up every penny and then some.
Old 01-20-2015, 08:50 PM   #14
jmedero
jmedero's Avatar
Wow really nice!!! Looking good.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 01-22-2015, 02:14 PM   #15
green723dr
green723dr's Avatar
I like that color... is it a factory green?
green723dr is offline   Reply With Quote
Old 01-22-2015, 06:49 PM   #16
1956cameo
1956cameo's Avatar
Doing a great job on that suburban!
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
Old 01-23-2015, 11:18 PM   #17
Gobuffalo
Gobuffalo's Avatar
Yes, that is the factory color. The code is 529 it's called medium blue green poly. The paint store told me poly ment metallic back then. The roof is the basic white Chevy used for years. The paint code in the glove box said 532 special paint. This breaks down to 529 (green) and 521 (white).
I used this color because it's different. It's also a pain. All of the interior pieces are the same color. Nobody reproduces anything in this color. It's all in pretty bad shape so I thought about a dark gray interior. Any opinions?
Old 01-24-2015, 12:56 PM   #18
LockDoc
The Older Generation
LockDoc's Avatar
Dark Grey would work good. I don't know if SEM makes a vinyl dye in the Blue/Green color or not. If they do you could have the seats and door panels done in a matching color and dye the dash pad and visors. I have had good luck with the SEM products.
LockDoc
Leon
Old 02-01-2015, 03:21 AM   #19
Gobuffalo
Gobuffalo's Avatar
Got a couple small projects done.
Because I put headers on I can't use my old dip stick. The installation instructions give you a p/n for a new one.
Got sticker shock when I found out a new flexible dip stick costs $65.00. So I staired at the one that came on the engine. I figured a little time with the bender and I could make it work.
Here's what I came up with.
Pic of the original. Stick way up there. Easy to get to.
Old 01-21-2015, 03:34 PM   #20
Justin@EntropyRad
Justin@EntropyRad's Avatar
Perfect Color choice.. thumbs up!
* Call me NOT the website number*
Justin Novick
(773) 303-8251
Sales/Support
Entropy Radiator / Engineered Cooling Products
"The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com
Justin@EntropyRad is offline   Reply With Quote
Old 10-28-2017, 02:46 PM   #21
Gobuffalo
Gobuffalo's Avatar
I've doing a lot of work to the Burb lately.
Got the hydro boost in and new cross over steering from ORD.
Old 10-28-2017, 02:57 PM   #22
Gobuffalo
Gobuffalo's Avatar
Also got the heater in, all of the sensors in for the Dakota Digital dash, new US Radiator and electric fans, inner fenders, battery box, etc.
Had to build an air cleaner system with a cold air box. It gave me a good place to hide the computer and some wiring.
Old 10-28-2017, 03:04 PM   #23
Gobuffalo
Gobuffalo's Avatar
Talking Re: The Bufmobl Build
Sorry about the pictures. Every time I rotate them, the web site rotates them back. Maybe one of you more computer savvy folks can give me some tips on this and how to post multiple pictures.
Old 11-14-2018, 09:33 AM   #24
Bigdav160
Bigdav160's Avatar
Sure is purdy!
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 11-14-2018, 08:14 PM   #25
rsavage
rsavage's Avatar
Love it and the build.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
