12-21-2014, 03:24 PM | #1 |
mini truck racer
1978 luv # 2
History repeats itself :
http://www.ebay.com/itm/Chevrolet-Ot...#ht_190wt_1429
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
12-21-2014, 03:45 PM | #2 |
mini truck racer
Re: 1978 luv # 2
My first Luv was a baby blue 1978 . I have a garage full of parts waiting on a decent body . I had to pay for it though . Here is the first one :
Before after
12-27-2014, 08:19 AM | #3 |
mini truck racer
Re: 1978 luv # 2
12-27-2014, 01:41 PM | #4 |
Re: 1978 luv # 2
It amazes me the money these trucks command now, just like the vegas and pintos.
That thing is exceptionally clean. |
12-28-2014, 09:28 AM | #5 |
Registered Truck Offender
Re: 1978 luv # 2
OK.... repeat after me
Hi, my name is Hotrod 80, and I have a Luv Problem (this "I can quit any time I want just isn't gonna fly any more"!!! <grins>)
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
12-28-2014, 01:40 PM | #6 |
mini truck racer
Re: 1978 luv # 2
Guess im the offical mini truck hoarder .
01-16-2015, 11:09 AM | #7 |
mini truck racer
Re: 1978 luv # 2
well got a bit done . Sent these to the chromer to have them straightened out and rechromed . Cleaned up and painted the brackets black .
Got the seat out and the door panels off and at the upolstry shop . Picked out the new materials it will be dark blue . Anyway just a small update .
01-18-2015, 10:29 AM | #8 |
Re: 1978 luv # 2
Sweet truck.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-18-2015, 06:29 PM | #9 |
Re: 1978 luv # 2
How many little trucks do you own now? You're as bad as my buddy Alex, (2) S-10 V8 trucks and (2) LUV V8 trucks.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
01-18-2015, 08:57 PM | #10 |
mini truck racer
Re: 1978 luv # 2
I have the Yellow 76' stepside , my primary race truck , the 89 S-10 with the 5.3 which my buddies wife is driving this year in DOT class , this truck the 78' which will be getting the 350 GM crate motor out of my 49' 5 window when I swap the 6.0 into it .
01-23-2015, 09:24 PM | #11 |
mini truck racer
Re: 1978 luv # 2
05-25-2015, 11:22 AM | #12 |
mini truck racer
Re: 1978 luv # 2
05-28-2015, 09:43 AM | #13 |
Re: 1978 luv # 2
What are you going to do with it when it's done?
05-29-2015, 06:19 PM | #14 |
mini truck racer
Re: 1978 luv # 2
Probably footbrake it and just drive it around on the street .
06-29-2015, 10:50 PM | #15 |
mini truck racer
Re: 1978 luv # 2
I ended up buying the white truck back from the guy i sold it to . Guess he got into money issues . I pulled the stuff i needed from the white truck . Rear axle , fuel system , exhaust etc and sold the body . These trucks in decent condition dont last around here , and a roller 5 lug swapped and V-8 ready was sold in about 2 days .
So the 9 inch is in the blue truck already ( 3.60 & 31 spline ) and the motor 383 out of the white truck is being inspected and fresh inserts . TH350 3500 converter drive shaft etc . Shouldnt be long now .
07-01-2015, 06:58 PM | #16 |
mini truck racer
Re: 1978 luv # 2
Got the motor apart yesterday and unfortunately they left water in the cylinders #8 being the worst . I wet everything down with WD-40 and pulled the pistons . Most of the cylinders just had dark marks in them . I hit them by had with a purple scotch bright pad and they went away . #8 has some ridges or grooves that I can catch my nail on . Going to ball hone all of these first and see if they clean up . All the bearings look great no metal in the pan . Talked to comp today about regrinding the cam .236/,245 .608/.614 on 108 hydraulic roller . Last time slip for this motor was a 6.88 @ 99 , it was probably coming apart at that point due to being over revved . Machine shop has pressure checked the heads and they are good . Not 100% sure this wont end up in my Yellow truck
08-20-2015, 11:30 AM | #17 |
mini truck racer
Re: 1978 luv # 2
Got a bit further this week . I bought an Eastwoods 135 mig welder which is 110 volt as I don't have 220 in my garage . Really surprised how well this thing works . Chassis shop would have charged me $500 at least and last time I had to take it back and have the mounts rewelded cause the didn't put the motor back far enough . Anyway: my old fastburn headed motor , th350 , 3500 TCI converter , block huggers , an HEI , and my Divinci gas carb . This motor had a touch of piston rattle on ethanol with 35 degrees of locked timing . It will be fine on gas with an advance curve . Leak down was good .
08-20-2015, 11:36 AM | #18 |
Re: 1978 luv # 2
I'm starting to think you have entirely too much time on your hands. When you finish this one,, can you come finish one of my projects!!!
08-20-2015, 03:31 PM | #19 |
Re: 1978 luv # 2
x2
i'm starting to think I should move closer.. I can make sure Hotrod don't run out of something to do on all them slow days..
JJ 71 SWB 360 Th400 4.56 |
08-20-2015, 04:53 PM | #20 |
Re: 1978 luv # 2
i had no idea these were valued parts. i see these at our local upullnpay all the time almost untouched.
back in the 90`s my uncle built up a 77 mikado lifted high and a turbo buick regal v6. kick ass truck
1967custom |
08-21-2015, 11:41 AM | #21 | ||
mini truck racer
Re: 1978 luv # 2
I hear this all the time . These truck were "Japanese junk" to a lot back then . They are surprisingly well built though . I would venture to say built better than a full size . Borderline industrial in many ways . Fully boxed frame from front to back , 7 welded in crossmembers front to rear , tried and true double a arm design , torsion bars like a Mopar , the factory rear axle puts an S-10 axle to shame and is a down sized 9 inch basically . dang near bullit proof 4 cylinder Isuzu fork lift motor . They were sold as a "Faster" in Japan and a KB 20 through 26 in Australia based on which model or options you got . They are getting very rare . Most are on the west coast or south . Story I heard was they came hooked 4 each to drive them into cargo ships and the beds came stacked on the top deck unpainted . They unloaded them here and the dealers painted the beds and installed them along with the bumpers . They were then sold as "assembled in the USA" . For this reason some of the beds rotted out quickly due to salt spray also the dealers sold aftermarket stepside beds . They are beginning to get rare now . This one will be completely stock except V8 , auto and 9 inch . No suspension mods at all except shocks in the rear . They ride great with a V8
08-22-2015, 02:08 PM | #22 |
Re: 1978 luv # 2
well if you need any parts im at the u pullit all the time and theres a bunch of them here. just let me know
1967custom |
08-22-2015, 03:17 PM | #23 |
Re: 1978 luv # 2
Following this one. My first vehicle was a 1976 baby blue Chevy Luv. Still have it sitting in the back.
08-31-2015, 11:05 AM | #24 |
mini truck racer
Re: 1978 luv # 2
Got a bit more done recently . Fuel system is finished . Driveshaft in . headers are on . getting closer . Radiator and alt bracket should be here Tuesday or so.
08-31-2015, 11:02 PM | #25 |
mini truck racer
Re: 1978 luv # 2
