Quick solution for single sub in a box with an amp.
In a quick and dirty fashion:
I'm very tall and the seat will be all the way back. I moved the tank to under the bed. I don't need to upset neighbors or make dogs' ears bleed. I have an updated AM/FM original radio with 180W to power 2 3" dash speakers and 2 5" kick panel speakers. Is there a single sub (sealed), in a box, with an attached amp out there for a little low end upgrade? It's a 69 C/10 shortbed. Again nothing crazy on pounding bass, just a fuller sound. Price isn't a ![]() ![]() |
Old member
I would try something like this. You could even put one on each side of the cab if you wanted.
![]() ![]() https://www.mtx.com/car-audio-built-...oofer-packages
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Quick solution for single sub in a box with an amp.
Someone else had a similar question and posted this: http://www.retrosound.com/product-p/hot-sub-8100.htm , I have no experience with this product but it sure looked cool.
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
Check a few posts down and some of the other members had some good ideas.
I'm going with this. Fits just about anywhere and a small mono sub runs it great.
http://www.jlaudio.com/cs112lg-tw3-c...-systems-93305 |
Crutchfield has several different powered subs that should fit easily.
Link to powered subs, sorted by price. Several flat 8's that should work. http://www.crutchfield.com/g_51000/P...rs.html?tp=114 I just did the stereo in my short step with a Kicker 8" sub under the seat next to a Kicker 400.4 amp (front two channels drive mids/tweets and rear is bridged mono into the sub.) Both fit under the seat well in my truck, but you would need to do some tape measure engineering to make sure yours would have sufficient space. Mine sounds awesome with 5 1/4" mounted in the door panels and the single sub.
