14 bolt Drum Seized
Just picked up a 78 K30 and the passenger rear drum is stuck something good. I have beat on him with BFH and heated it up with a rosebud. ..and have sprayed wd40 and a mixture of ATF and acetone. Axle shaft has been removed as well. Even tried to pull it off with chain and truck! NOTHING has worked. Seems to be stuck towards the top of the drum. Any ideas or suggestions? ?? Thanks in advance
Re: 14 bolt Drum Seized
Do you have the drum and the hub of the truck? You should just have to press the studs out of the hub/drum and they will come apart. Unless its a later rear axle with slip on drums then you should just need to back the brakes off if there is a lip worn into the drum so you can slide it over the shoes. You should post a pic
The drum and hub are on the truck. ..and the drum is stuck, probably on the shoes or something.
So you have the spindle nuts off then? Did the outter bearing come out if you move the hub up and down? If the outter bearing is off then maybe the inner one spun on the spindle? Even then you should still be able to pull the hub and drum off the wheel seal and inner bearing without to much trouble. Will the hub turn at all?
The bearing that is visible from the outside has not came out which I thought that bearing has to come out from the inside of the hub?? Yes I removed the 2 spindle nuts and washer. The hub/drum will not turn a bit but it seems a little loose pulling side to side and at the bottom but seems stuck towards the top center area...as far as I can tell at least.
#6 | |
1971 Chevy K30 / 454 / TH400 / NP205 / Dana 60/14 bolt FF on BFG Baja 37's - Build Thread : http://67-72chevytrucks.com/vboard/s...d.php?t=647877 2018 Silverado 1500 5.3 LTZ Z71 - daily driver 2019 Tahoe Z71 5.3 - (Wifes daily driver) |
![]() Join Date: Mar 2003
Does the drum spin? If so, there is something you didn't remove or back off. If it won't spin then the shoes are rusted to the drum or the adjuster is spun up too tight
if the adjuster is spun too tight, what is the proper procedure to loosen it (which way to turn it and best tool for it)??
if the shoes are adjusted to tight or the drums have a groves from worn shoes. The adjuster only goes 1 way unless you use push in on the lever arm to back out the adjuster .
If that does work than cut the heads off the shoe hold down pins. It will give you enough room to get the drum off.
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
I mean the heads of the hold pins on the outside
Yes, on the outside of the backing plate. There about 3/16" in size kinda like a nail. You can also drill out the head .
Here is what the drum looks like when off looking @ the backing plate. The springs and cups are about 8 & 4 o clock.
Cool.....I will definitely try that this week. Thank you for the info and pic!
