05-06-2015, 11:04 AM | #1 |
4x4 axle questions
i have a 1975 chevy 12 bolt front end and was wondering if i was able to swap to a 10 bolt from the ball joints out to upgrade to newer parts cause it is hard to get parts for a 75
05-06-2015, 11:32 AM | #2 |
Re: 4x4 axle questions
I'm curious why you have a 12bolt in the front end for? You should have a dana44?
05-06-2015, 11:36 AM | #3 |
is the OP mis understood what a 12 bolt is and is counting the cover bolts?
should be a dana 44 or, if replaced, a 10 bolt.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
05-06-2015, 07:40 PM | #4 |
He has a d44 with the large lockouts and probably has bad hubs or a combination of bad parts that are no longer available. Any ways, to answer your question. You can keep the knuckles on and just swap from the spindle out. Can use the same backing plates/(caliper mount) and calipers, just swap out the spindles, bearings hub/rotor assy and locking hubs
05-06-2015, 09:07 PM | #5 | |
05-06-2015, 09:56 PM | #6 |
203 (full-time) was the only T-case option in '75??
Who needs a Hemi when ya got a Chevy! |
05-06-2015, 10:24 PM | #7 |
05-06-2015, 11:32 PM | #8 |
All parts are available for both the smal and large bearing dana 44s. Check napa or other local parts store of your choice. They should have the books to look up all the part numbers for bearings and seals.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
05-07-2015, 02:21 AM | #9 |
I think the reason he can't find parts is hes looking for a 12 bolt steering axle.A dana 44 all parts can be ordered online somewhere.Only gm axles that are hard to find parts are the napco and the eatons.
05-07-2015, 03:09 PM | #10 |
yes i thought it was a 12 bolt cause the cover has 12 bolts. but when i went to parts store to get all new hub assembly's with bearing rotor etc they said their is nothing reproduced for my axle.i need to replace it bearings wore out. i would appericate if any of you guys can help me steer toward the right place.
05-07-2015, 03:20 PM | #11 | |
All in you should be looking around $150-160 dollars for the materials plus the extra cost of the tools. Rotors are also a separate item and there will be two diff sizes of that oo. |
05-07-2015, 04:42 PM | #12 |
i have tryed to look these part numbers up on the orignals but they are nowhere to be found thats why i wanted to switch from ball joints out to a 80s model front end so i can get parts just need to know if i can or not i have the tools
05-07-2015, 05:05 PM | #13 |
05-07-2015, 05:24 PM | #14 |
Go back to the parts store and tell the guy what year and model your truck is. Have him look up the parts. Don't confuse him by trying to tell him what axle you have would be my recommendation.
05-07-2015, 08:33 PM | #15 |
How about a picture of the axle from a front on view and a pic of the knuckle
05-07-2015, 08:35 PM | #16 |
snakester,
Is your truck 1/2 ton (6-lug) or 3/4 ton (8-lug)? What is the outer diameter of the hub, where the lockouts bolt on? Can you take a picture of your diff cover, and one of your hubs? Just because it is a 75 doesn't mean it has the original axle. many parts get swapped on these old pickups over the years. If you can answer the questions above and provide a couple pics we can identify the axle type and ensure you get the correct parts for it.
05-08-2015, 08:10 AM | #17 |
Either way I'd go to a different parts store if the guy says parts aren't available. Everything from the knuckles out is interchangeable, even between other makes. (GM, Ford, Dodge, IH etc)
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
05-08-2015, 09:03 AM | #18 |
the truck is half ton 6 lug. i can upload pictures later tonight of the front end. i do not know the measurements. but i will have everything uploaded tonight so you guys can help me thank you
05-08-2015, 09:31 AM | #19 | |
Rebuilding the front end of a D44 is so simple but just time consuming and the ujoints are the biggest headache. |
05-08-2015, 10:28 AM | #20 |
thats excatly how it was when i took it apart the outer bearing was smaller and the inner was bigger. ive had it all apart before just need all new parts. im acually rebuilding the front end then selling it. it has a 1987 body with a 75 frame down its swb
05-08-2015, 10:55 AM | #21 |
Since it is half ton it should use the same parts as all 1/2 ton truck axles from 73 to 87. It shouldn't be a problem finding parts. If it is the original axle then it is a dana 44. If it is a later model then it is likely a GM 10 bolt. Either way I believe the parts outside of the knuckle to be the same for both.
05-08-2015, 11:03 AM | #22 |
when we searched part numbers they were diffent bearing numbers i could just measure the size of the bearings and see if it will slide right on the spindle or not
05-08-2015, 11:11 AM | #23 | |
If they are competent they will have the dana book or spicer book and in 10 minutes have the parts to you. Chain part stores are useless for this crap. |
05-08-2015, 11:50 AM | #24 |
okay i will go to some 4x4 places in town and post if i find anything out thanks for the help
05-09-2015, 02:48 AM | #25 |
Or you should be able to order everything off rockauto.com you need.
