remove A arm and remove balljoint
remove old bushings & shaft disassembled screw in one bushing screw shaft into bushing screw in 2nd bushing next the balljoint use the grade 8 bolts install back on truck tighten everything up & grease Some tips. Screw in the first bushing all the way into the A arm. then after greasing the shaft, screw it all the way into the bushing, then unscrew it out one turn. Then screw the other bushing into the A arm. Snug them down good. I have seen the bushings tack welded to the A arm, just be sure to tack them so they can be removed later. There may be other ways to do this, but this is how I've done it over the years. If anyone has anything to add please feel free.....eb |
![]() Join Date: Dec 2001
That is great we need more info like that on this board. I know this will help me when I start on my suspension. Keep up the good work.
Dave ------------------ 68 C-10 Custom LWB 307 V8 Three-on-the-tree Lexington,NC davideowens@lexcominc.net
68 ![]() 307 V8 Lexington,NC davideowens@lexcominc.net God Bless America |
Very timely, I'm about to do my balljoints. Ordered moog uppers, one was missing the hardware, called parts plce which ordered a new one, same part different hardware, missing bolts. Moog has some serious quality control probs.
I wasn't planning on doing my A arm shaft, but prolly idler and pitman and lowers. Is there a test for the state of your A arm bushings? ------------------ 71 GMC 2500 Custom Camper 71 GMC Suburban 1500 Super Custom 71 Chevrolet 1500 Donor http://www.able-bravo.com
71 GMC 1500 LWB |
Crash Test Dummy
Can we get Josh or one of the admins to move this to the "Tech Tips" or "Tech articles" section?
The more hair i lose, the more head i get. Build Sheet: 1969 C-10 short fleet Constructed by taking a 3/4 ton rolling frame from one truck, adding a rust free AC Cab from another, then a bed from another, 1/2 ton front suspension & brakes from another,add in one Goodwrench crate 350, painted DuPont Arctic White,and driven daily. |
Jostrans68
After 20 yrs parts experience its not moog you should see the way this stuff is handled at the Independent Whse's I watched the guys throwing parts to a guy ona ladder 4 out of 10 missed,The mfg's cant control this....
My 2 cents ------------------ 68 c20 in progress 327 TH400 tach dash Disc Brakes and soon 3.90 rear gears.. have many new parts now just need the time..... Sound Familar
![]() former 67-72 now with a 96 silverado |
eb, Thanks soooo much for posting that kind of stuff! It took extra time out of your project to do that, but newbies like me can't get enough of that sort of thing! THANK YOU!! Darren
------------------ Darren Washougal, Washington darrengale67@hotmail.com NOT the NetZero e-mail. 1972 GMC C1500 (Bone Stock) Saving / Looking for a 72 3/4 Ton 4X4 Automatic with little or no rust.
Washington State 1967 Chevy C10 LWB Rodstoration In Progress. 1972 K20 Cheyenne Super |
You are certainly welcome Darren, but really I just like playing with my camera....LOL
Thanks for all of your time to explain with pictures. I am in the process of doing just that. Where did you order the bushings?
Great work.....
Ken Smith 99 C5 Torch Red Coupe 85 Chevy Candy Apple 70 Chevy 1/2 in process.Semi-gloss black powdercoated frame & suspension, disc brakes up front, 3" drop spindle(Beltech) 5 lug 3.73 rearend, ZZ4, Sanderson headers, 700R4, Air Ride system, Summitt 16 gal fuel cell, Holly mech. fuel pump, |
you don't want to do the final torque on the shafts untill you get the truck back on the ground. I put jack stands under the bottom a-arms and load the suspention. Then you do the final torqueing on the shafts
------------------ 71 basic C-10 350. The only option is the rust.No nothing on it, but thats all about to change. <A HREF="http://www.geocities.com/stevemau/slam33page.html?1004806705410 " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A>
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
all pretty well covered ebfabman,the only thing that I can add.....have plenty of beer on hand! .......69 longhorn
http://community.webshots.com/user/hotrodhorn |
aka Crusher, Crushergmc
Has anyone else noticed that the bolts in they're ball joint kit were metric. Damn, I got metric bolts on my truck!
------------------ "KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" |
