05-21-2015, 07:07 PM | #1 |
3/8 fuel line fitting to -6 AN ?
I,m trying to find a fitting to go from a steel 3/8 fuel line which has ,Im guessing a male 1/2 in. fitting to convert to a -6 male to run to my mech. fuel pump from the tank.I don,t seem to see one online but don,t know if I,m wording it wrong.I see the ones that have a Ferrel style but was wanting the other so I don,t have to cut
05-21-2015, 07:17 PM | #2 | |
Registered Truck Offender
Re: 3/8 fuel line fitting to -6 AN ?
Here's a link to Slummits list of Earls Inverted flare to AN- fittings
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
05-21-2015, 11:15 PM | #3 |
60-66 Nut
Are you wanting to go from a 3/8" inverted flare to a -6 male?
05-22-2015, 12:02 AM | #4 |
meowMEOWmeowMEOW
low pressure lines can use a hard-tube to AN adapter, or you can buy a JIC 37* flare tool and actually just flare one on. They make 1/2" to 3/8" reducer fuel fittings, and then they make 3/8 NPT to -6AN adapter fittings.
You may not find a "one-fitting" solution, unless you flare it yourself or use the hard tube adapter. The problem with AN conversion fittings is that odd-size stuff has a 2-3x higher price than commonly used ones.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
05-22-2015, 09:10 AM | #5 |
It is a 3/8 hard steel hard line but I was measuring the flared male fitting on the end which looks like1/2 inch
05-22-2015, 09:47 AM | #6 |
mini truck racer
You will have to find a hydraulic or fitting shop , but they are out their . I have a good hydraulic shop in town ( he also drag races ) For my 69 Camaro I have small amount of rubber hose to the pump and an inverted flair male to -6 in the pump and -6 with 2-90 's on each end going to the carb
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
05-22-2015, 09:53 AM | #7 |
Finally found it I,m sure.Just had to get the right wording. NPT. inverted flare,45 degree, 37 degree,male ,female ARRG.,been along time doing this http://www.summitracing.com/int/part...0610/overview/
