06-22-2015, 12:58 PM | #1 |
No Clutch
Pulled the motor in my C10 to fix leaks and replace clutch. We cranked yesterday (Sounds great!!), but we do not have a clutch at all. When I push in the clutch pedal it feels like I am only pushing against the clutch pedal return spring. It grinds when trying to put it in gear, and will not go in gear. I only tried reverse - was afraid I might run through the back of the shop! The clutch rod is adjusted to its maximum length. The clutch was working before I pulled the motor - just figured i would replace since the motor was coming out. The clutch was last replaced in 1994.
What could I have done wrong? What can I look for without pulling transmission? Or am I just putting off something I am going to have to do? The photo below is from my Haynes manual. Is the clutch disk orientated the right way? |
06-22-2015, 01:04 PM | #2 |
Re: No Clutch
It sounds like the throwout bearing is in backwards to me...
06-22-2015, 01:23 PM | #3 |
The Older Generation
Re: No Clutch
Did you use the same style of pressure plate as you took out? LockDoc
06-22-2015, 01:38 PM | #4 | |
Re: No Clutch
06-22-2015, 01:42 PM | #5 |
Re: No Clutch
06-22-2015, 02:53 PM | #6 |
Re: No Clutch
Yes the larger turning surface toward the motor side. Can you see up in there to judge what's going on with the inspection cover off on the bottom? if the fingers are depressing then the pressure plate is junk. otherwise some dimension has changed to make it so your not getting enough throw. was the throw-out bearing changed too? If so are you sure that height was the same?
06-22-2015, 04:05 PM | #7 |
Re: No Clutch
Did you replace the throw-out bearing? They have a couple of different heights of throw-out bearings It may be a long shot but can happen. If not can the adjustment be changed.
06-22-2015, 04:24 PM | #8 | |
Re: No Clutch
06-22-2015, 04:26 PM | #9 |
Re: No Clutch
I will climb under tonight to see if I can see anything, covers are off - not sure if I can get a pic...
06-22-2015, 07:26 PM | #10 |
Re: No Clutch
did you cut the flywheel the different thickness throw out bearings are for when the flywheel gets thinner there has been times I had to make a new adjuster rod . it really sounds like it is out of adjustment if something with the clutch plate was backward you would not be able to bolt it together the throwout bearing will usually only go one way . I have seen bad pressure plate right out of the box .
06-23-2015, 10:38 PM | #11 | |
Re: No Clutch
06-23-2015, 09:15 PM | #12 |
Re: No Clutch
any updates? very curious about this one.
06-23-2015, 11:01 PM | #13 |
Re: No Clutch
Not a lot of update just a photo of the throw out bearing. Kinda hard to get a decent pic. I will get under the truck tomorrow or Thursday evening and have someone push the clutch pedal so I can watch the bearing. Question: with the clutch released (pedal not pushed in) should the throw out bearing be touching the pressure plate fingers?
06-24-2015, 01:43 PM | #14 |
Re: No Clutch
You said you pulled the motor. To do so, you had to disconnect the bellcrank at least on the engine side. Is your bellcrank properly re-mounted? If it is loose on one or both ends, the clutch fork will not be depressed properly, the tranny will not go into gear, and the only resistance you will fee is the pedal return spring.
06-24-2015, 02:50 PM | #15 |
Re: No Clutch
I had the same problem on a 67 with a 3 speed. I hate to give you the bad news, but you more than likely have the clutch fork retaining clip in backwards or not fully seated on the ball stud. The clip has a curve to it and needs to be seated correctly to allow the clutch to be positioned correctly. I had to remove the trans again and the bellhousing to get it right. You'll know fairly quick if it's right, you should about 3/8"-1/2" free play in the peddle and about 1" of threads past the nut on the zbar.
06-24-2015, 11:19 PM | #16 | |
Re: No Clutch
06-24-2015, 11:21 PM | #17 | |
Re: No Clutch
06-25-2015, 08:09 AM | #18 |
Re: No Clutch
There is a recessed slot milled around the hole the clip rides in, and the curve goes toward the hole. I would strongly recommend you pull it all, then assemble the bellhousing, clutch fork, retaining clip, and clutch fork boot all together. One last thing, you should get a firm "pop" when the clutch fork is seated on the ball, if not, then it's not installed correct or the clip has lost it strength. You can still get them from GM.
06-28-2015, 03:58 PM | #19 |
Re: No Clutch
Did you put # 3 in the pic back on the pushrod? And if so, can someone lay under the truck and watch what happens when the clutch pedal is depressed?
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
06-28-2015, 04:05 PM | #20 |
Re: No Clutch
your missing the little fork piece on teh end of the rod number 3 in the picture above that will take out the 1/2 of play you have thats causing your clutch not to work.
07-01-2015, 02:37 PM | #21 | |
Re: No Clutch
Question about this (and all who mentioned #3 missing). I know it needs to be on there, but is seems to me that it is on the backside of the fork and would not affect the disengagement (pushing the pedal) of the clutch. Looks like it would mainly keep the fork from popping off the rod if you popped the clutch. What am I not understanding here? Same with #7 (the clip). The big brown truck is supposed to bring them tomorrow I have ordered the bell crank seats, spring, spacer, and washer to see if that will help me tighten up tolerances. |
07-01-2015, 05:14 PM | #22 |
Re: No Clutch
You are wrong about piece #3. It is not on the backside of the fork. It goes on the end of the push rod and it is the part that pushes the fork. The way you hav it now, you will end up pushing the push rod through the hole in the fork in no time.
It is not a nut that holds the push rod from falling off, it is pivot point that pushes the fork.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
07-01-2015, 06:59 PM | #23 | |
Re: No Clutch
07-01-2015, 09:32 PM | #24 |
#3, like this...
Posted via Mobile Device |
06-28-2015, 05:05 PM | #25 |
Re: No Clutch
Yeah, you're missing the nut (3) at the end of the push rod. Also, you have the wrong style of spring clips (7) on the push rods at the crossshaft.
