08-16-2015, 03:46 PM | #1 |
RPM at freeway speed?
I have a new crate motor, 6.2L LS3, 4L65E trans. Current rear gear is 3.73. GM recommends 3.42 for this engine/trans combo. With the 3.42 and my tire size, RPM's calculate to 2201 at 70 MPH. My question is this, is 2200 rpm going to be in the right range for optimal fuel mileage. I would assume so from a GM engineering standpoint but was looking for real world scenarios. Thanks
08-16-2015, 05:28 PM | #2 |
Re: RPM at freeway speed?
Sounds like a perfect combination to me!
I would not think you would notice that much difference in MPG , are you thinking that 2000 RPM's is the perfect number? I am thinking out loud, the difference between 20 and 21 MPG difference. You could always reduce the tire height by 1/2 inch or so.............. after you burn the first set off!!
08-16-2015, 05:30 PM | #3 |
I don't know about fuel mileage because I don't care, but I'd keep those 3.73s all day long...
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
08-16-2015, 07:12 PM | #4 |
3.42 compared to 3.73 is not much of a ratio change to warrant changing gear sets.
08-16-2015, 07:57 PM | #5 |
08-16-2015, 08:46 PM | #6 | |
meowMEOWmeowMEOW
2200 is fine on the highway, and I'd say its right around where most of us sit. Your stall converter and lockup settings will also affect the seen vs calculated rpm. My 4l80e/ 373 12bolt sits about 150-200rpm higher, but the converter has a slipping problem when hot in 3rd.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
08-16-2015, 09:05 PM | #7 |
I'm running 3:42 gears with my 6.0l/4l80, and it's right around 2200rpm @70mph....and 2200 is right about when this thing starts to pull... I wouldn't be able to keep tires on it at all with 3:73 gears! if you were doin a lot of freeway driving you could run 3:23 gears easily with that ls3...
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
08-16-2015, 11:48 PM | #8 | |
08-24-2015, 02:07 PM | #9 |
Old member
6.0 4L80E with 4:10 gears and I'm cruisin at 2400RPMs @70MPH, tires are 29" tall. Truck gets about 16-17 MPG.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
