03-29-2002, 12:49 AM | #1 |
HEATER PROBLEM NEED HELP!
When I turn my heater on the fan runs really slow and blows weak.But when I put direct power to the blower motor it blows strong. Could someone tell how I can fix it to blow stronger? Thanks inadvance for your help.
------------------ 72 CHEVY 4X4 BLAZER 69 CHEVY SWB 95 HARLEY DAVIDSON NOSTALGIA [This message has been edited by GABE310 (edited March 28, 2002).]
68 CHEVY SWB 95 HARLEY DAVIDSON NOSTALGIA 68 CAMARO CONV 65 CHEVELLE CONV 39 CHEVY CABOVER |
03-29-2002, 12:58 AM | #2 |
Sounds to me like you either have to much resistance in the wires going to the fan motor. If you have a voltmeter backprobe the wires to the fan and see what your voltage is if it is not battery voltage with the fan on high you have either a bad blower motor resistor or wires going to the fan.
Hope this helps. You can use a 12volt test light and if it glows only dim then same problem. Let me know what you find okay?
"Red-heads not war-heads, Blondes, not bombs, Brunettes, not fighter jets!" Fligh of the Choncords 72 burb 3/4 ton 2wd 06 2500 suburban 8.1L 4x4 84 chev 4x4 diesel 96 Geo Metro with the 4cylbb, lol! Almost 300k just won't die! 89 Honda Civic, runs on the smell of an oily rag! 2008 Aerolite 26qs Travel Trailer (aka "THE BARN") |
03-29-2002, 01:24 AM | #3 |
Mine done that and I had to replace the fan switch. It had some bad (worn out) contacts and was not kicking in the high speed relay.
------------------ Zurbo's Chevy - 1972 Black/White Cheyenne Super. 400 Big Block /THD 400, factory air and tilt. My other Chevy - 1998 Camaro SS
Zurbo's Chevy - 1972 Black/White Cheyenne Super. 402 Big Block /THD 400, factory air and tilt. My other Chevy - 1998 Camaro SS |
03-29-2002, 01:35 AM | #4 |
Jostrans68
on the heater box there is a reostat (sp) that controls this it is bad
------------------ 68 c20 in progress 327 TH400 tach dash Disc Brakes and soon 3.90 rear gears.. have many new parts now just need the time..... Sound Familar Tacoma Wa. The Rain capitol of the USA
[CGTW Member former 67-72 now with a 96 silverado |
03-29-2002, 12:40 PM | #5 |
It is most likely the switch. If the resistor goes bad, the fan will usually only work on high, and not on the lower speeds.
------------------ Tim
Tim |
