09-18-2015, 08:22 AM | #1 |
Project Eugene: 1949 5 window
This build started years ago in my head. I have been a Jeep guy for years- this is our current family rig. It's sort of a 1949 Willys. Although the windshield is a 3b, the cowl and hood are from a 2a, the grill is an MB, and the tail gate is a repro. Everything else I fabbed. Rear axle is from a dodge, front is from a Ford, Chevy 4.3 V6 from an S10, and a TH350 with a manual valvebody.
It gets around. Wifey loves to drive it too. I built that rig in a standard 2 stall garage at my old house, and covered EVERYTHING in grinding dust and welding slag. So, wifey said no more major projects until I have a dedicated space to build in. That required a new house, so eventually we moved and originally the contractor that was flipping our house was going to build the shop for us as part of the deal- well, he backed out 2 weeks away from closing, so then it became a waiting game of when rates were right that we could take out the money to build it ourselves. Here's the house prior to getting started. Staked out shop corners Cut down the trees and dug a BIG hole. I had the excavating and concrete/ block work hired out. Did everything else myself with some friends that were very generous with their time. Then momma had to have landscaping The kids "helped" quite a bit actually. My daughter is pretty good with a roofing nailer. Then we moved in. That all brings us up to date as of about 3 weeks ago. I hung the heater last week and will run the gas line this weekend- Now the grass is growing, and it's finally time to get started on a new project. When I was 18, my father committed suicide. There were a lot of things we didn't get to do together, and I have always wished we could have built something as a father/ son project. Well, the shop was phase one of my plan to do that with my kids- which was the natural lead into phase 2. This is Eugene. My dad's name was Robert Eugene Sutherland, so it's a fitting tribute to him and the legacy we are continuing despite his absence. The goal being to teach the kids to turn wrenches, cut metal and weld, and see a project through from start to finish. Eugene is a 49 5 window that needs a lotta work, but the price was right- so it followed me home 2 days after getting final sign off on my building permit for the shop. LOL The cab is in decent shape, along with the doors, front fenders, hood, grill, and bed sides. But I spend the rest of this years budget on patch panels for everything, so that will be what we work on for the winter. The plan is an S10 frame, bags, cut the 3600 to a 3100 (I know, I know) and an LS drivetrain. Nothing fancy, just solid sheet metal and a lot of love. I will be asking LOTS of questions when I can't find answers on this wealth of knowledge site. I have never been too proud to ask questions or act like I know all the answers- cuz I sure dont. FIRST QUESTION: Any particular order I should start putting the patch panels in? I am replacing the floor, kick panels, firewall, rockers, and lower cowl. My assumption is I should start at the floor and work my way up and out, but I'm open to ideas. GAME ON |
09-18-2015, 12:25 PM | #2 |
Re: Project Eugene: 1949 5 window
Shop looks great!!! Since you're looking to do a S10 frame swap, make sure to review these great tips. Skymangs S10 Swap How To sticky http://67-72chevytrucks.com/vboard/s...d.php?t=632686 I'm sure you've reviewed over and over, but its good to point it out. Second, based upon all the S10 builds, you may want to get your hand on a frame first and get all the work done on it first. That will help you determine the work that will be needed on getting panels done. Again welcome on congratz on the build! |
09-18-2015, 12:44 PM | #3 |
Welcome to the group, look forward to your build...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
09-18-2015, 02:49 PM | #4 |
Thanks guys- I appreciate the welcome. I have read Skymangs thread at least 300 times already, but it was good to read it again! Haha.
I am planning on using EZ Swaps stock body height kit, since he told me that his kit puts the running boards and bottoms of the fenders level with the bottom of the frame rail. So, my assumption is that I dont want to do a body drop since I want it to lay frame. He also accommodates for the LS motor with his engine mounts. Anything else I need to know about this kit? Why do you recommend starting with the frame? Since I am using the kit dont I want the stock holes to line up? |
09-18-2015, 06:04 PM | #5 | |
Would hate to have you have to trim up some panels that you patched because doing that takes up that valuable resource...time. of course these are just my thoughts...I don't know your time frame /budget/ donor availability, so my thoughts are worth a grain of salt. Hopefully some of the S10 frame swap maestros will chime in. Last edited by iowaboynca; 09-18-2015 at 06:22 PM. |
09-18-2015, 07:05 PM | #6 |
Welcome Hulk64! That is a great shop you built and a very cool Jeep.
There was a really good thread on here about floor and I think rocker replacement too. Will see if I can find it for you. |
09-18-2015, 07:09 PM | #7 |
09-19-2015, 01:16 AM | #8 |
man I love red trucks. everything I find is green. I did see an original maroon one today.
11-03-2015, 09:26 PM | #9 |
Well, I made some progress- not a ton, but enough to merit a post at least...
Shop has heat, insulation, and a big screen TV now. First truck focused project was rebuilding the bedsides. I tried patching only the holes- and I didn't quite go slow enough (And forgot to change to .023 wire, and didn't move frequently enough, and was trying to go fast, etc.) and warped the snot out of the first one. Ouch. At first I super pissed, but I regrouped and cut the spot welds on the stake pockets and chopped the top angle and rolled edge off length wise and bought a 4x8 sheet of 16 gauge to start over on the bottoms with right sized wire, and a more patient mindset. I also cut them down from 3600 length to 3100 length- so I relocated the stake pockets at the same time. Much less warped> LOL Honestly, the best part was getting my son involved. Here, he didn't want to go put his boots on so this was his solution to no sparks in his socks. Loving getting his hands dirty. Finished product. The good news is that all the cool patina on the top rail is still under there and this primer is close to the stock color, so when I run through the new paint it will still come through as patina, but all the metal will be solid. I test fit the doors and the gaps are pretty good, so I got to bracing the cab last weekend so I could roll it on its back and start chopping out the rot. So now that it's braced I started cutting out the yuck. Passenger side rocker is first. After putting it in and taking it out to trim about 265 times, it's pretty close to being ready to get welded in. The other good news is I found some really solid rear fenders and a long bed S10 frame that I have being held for the winter until I am ready for it in the spring. So I am stoked to have most of the parts located (And paid for) for phase one. Which brings me to my first question: How do I get this bracket out nicely? I have a new hinge pocket panel- but I need this bracket to bolt the hinge to and it is welded in there in 7-8 spots. Do I just cut them all out? Or can I get a replacement for this somewhere? Everything around it was junk and rotten so I just cut the whole thing out to work on. Figured I would ask before I start hacking. Thanks for the help fellas! Last edited by HULK64; 11-03-2015 at 09:51 PM. |
11-04-2015, 03:20 PM | #10 |
sounds a lot like my build except im not using the swap kit. good looking shop man. ive got to replace the floor in mine aw well but I think im going to wait until I get my motor and trans in place first so I don't run into any issues with the trans tunnel. Ill follow along though for sure good luck with it man
big_moss bagged 51 3100 build |
11-16-2015, 08:40 PM | #11 |
I got some of the panels put in, most of them are even straight!
Before: (Drivers side for reference) Had some gaps to sort out Turned out alright Starting to fab lower floor pieces |
11-16-2015, 09:07 PM | #12 |
Awesome shop......and props to you for starting a project with your kids!!
Subscribed!! |
11-25-2015, 09:56 AM | #13 |
I got the driver's side wrapped last week, turned out pretty well.
So then we had an ugly firewall and Flintstones worthy floor to deal with. Time to fire up the grinder. It will take me a little bit to fab up the kick panels, but next up is this little beauty/ floors and taller trans tunnel. |
11-25-2015, 11:00 AM | #14 |
Really nice work Hulk. Did you fab the firewall?
11-25-2015, 11:49 AM | #15 |
Thanks AD!
I didn't fab it- it's from Absolute Sheet Metal in AZ. It's a really nice piece, looking forward to putting it in! |
11-25-2015, 03:07 PM | #16 |
HULK64, guys don't normally show their bottoms, cab bottoms that is, but in post #13 above, 4th picture down you have. At the bottom of the picture showing the back end of the cab floor, there are channels on each side to mount cab shackles. I was of the impression these shackles were on cabs 51-54 and possibly 55.1 and not on cabs 50 and earlier. My question is do you know if these channels are on all AD cabs even when the cab has a center mount on the back? My cab is 54 and has these channels but I know nothing about earlier cabs.
Love your shop. Clay |
11-25-2015, 03:36 PM | #17 |
Clay- are you talking about the floor supports that tie into the rockers that the cab mounts bolt through? I would assume all cabs would have these, as you would want a supported structure to bolt the cab to the frame. Or are you referring to something else and I am not understanding?
11-25-2015, 04:34 PM | #18 |
We are talking about the same. If your cab is 49 than that cab did not use the shackles in this location. And yes, if you are building cab stands they will need to connect in this location.
I have just verified from another source that these "c" channels are in face on all AD cabs. This is something I was not aware. Thanks for your response and please accept my apology for the bother. Clay |
11-25-2015, 04:39 PM | #19 |
Nice progress, how did you fix those gaps?
12-30-2015, 09:16 PM | #20 |
Very nice work on the replacement parts, looks great...Jim
12-30-2015, 11:48 PM | #21 |
You made good progress with your time off. Looks great.
1949/1954 with LS swap-yeah! http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos |
12-31-2015, 06:12 PM | #22 |
Just a bit of progress today, one side done. Hoping to get the other side done and the door shaved to fit before I have to go back to work on Monday...we'll see!
Before: During: After, all blended and happy: |
12-31-2015, 06:21 PM | #23 |
Looks great, nice job...Jim
12-31-2015, 10:12 PM | #24 |
Great job on the floor and firewall!
01-10-2016, 10:46 AM | #25 |
More progress this weekend.
Filled the cab corner gaps with some hand fabbed pieces. Before: After: Filled the filler neck hole: All gone: Body worked the cab corners while I was at it. Far from perfect, and I was trying hard not to use any filler, but they do look better. Body worked the upper cowl. I was gonna try and use lead, but I got skerred. Drivers: Passenger: Even got motivated enough to start working on the door gaps. Before: After: Got new bear claw latches for the doors since my old latches are welded to the skins right now, looking forward to getting those in and not having to worry about my doors opening at speed... |
