10-09-2015, 10:37 PM | #1 |
Help!= Rear control arms 66 P.U.
Hello, I blew my 66 short stepside all apart and found that the rear comtrol arms have a separation of about 1/4 to 3/8 inch about the last 2 feet along the length of the atm. How did chevy hold these 2 channels together? I expected there would be rivets but there are none. There are 5 holes through the web of the channel could I put grade 8 bolts thru them and pull it back together. Or could I weld some plate along the top and bottom? Thanks, Jimmy
1966 chev. short stepside |
10-09-2015, 10:53 PM | #2 |
Re: Help!= Rear control arms 66 P.U.
I wouldn't weld them up completely as they need to flex under load. Mine are the same as yours due to rust scaling pushing them apart. When I get a chance I'm separating them, cleaning, painting, then using grade 5 bolts like you suggested and maybe a weld here and there for good measure.
10-09-2015, 11:24 PM | #3 |
here are some pics of what i did to mine, the plate was added just to rear section and a couple welds on the rest
10-09-2015, 11:40 PM | #4 |
Thanks for the ideas, I just found ECE early chassis enterprises sells a trailing arm reinforcement kit for 129$. I" m a little relieved because I don't want to spend 400=700 for new bars Thanks for the replies, Jimmy
10-10-2015, 12:28 PM | #5 |
Moderator
10-11-2015, 07:07 PM | #6 |
Wow those look just like the ones I pulled out today. I'm supposed to get another pair next weekend. Little brother hooked me up from one of his parts trucks.
10-10-2015, 07:31 PM | #7 |
Bad thin is that the rust pushing them apart used to be trailing arm material. I think you will find if you sand blast them thy are very thin in places. I would look for a good set.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
10-11-2015, 12:58 PM | #8 |
Jay thanks for sharing, mine aren't that bad, Jimmy
10-11-2015, 06:16 PM | #9 |
Moderator
No prob, I had to ask the same question a couple years ago! One of our members kindly hooked me up with a nice used set.
Tags |
rear axle, trailing arms |
