what's a good welder to weld patch panels
I like a miller found a miller 210 at a good deal is it to big
Re: what's a good welder to weld patch panels
Fount a miller 210 I think it mite be to big
![]() Join Date: Apr 2015
I got a Hobart 190 mig with a spool gun kit. I payed $850 free shipping a yr ago from cyberweld. A little 120v will do panels but I needed something bigger to do frames. if you're going mig that is and u need to buy the tank and gas.. because flux is no good for panel work imo.. iv heard good things from lincon welders for starters i never ran one thowe.
![]() Join Date: Oct 2009
second the Miller. Millermatic Auto-set 211 is my go to.
You will want a welder that will run .023 size wire for sheet metal to minimize warping
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
Looked at miller 211 they change it a lot look smaller
Miller is good quality but like anything else, it could be used and abused. Ive worked in some production shops that ran 3 shifts so those machines were well worn. If it came from some guy who didn't use it much and the price is right, snag it. I paid $1200 for my millermatic 210 back in '04 and it has maybe an hour use on it, lol. They don't even make that model anymore. Ive used lincoln and esab. Both good also.
What's the smallest wire you can use on the 210
The 210 accepts the following drive rolls:
V-Grooved Drive Roll Kits and PNs (solid wire) #204 579 .030 & .035 in (0.8 & 0.9 mm) Combination (Reversible) #087 131 .023/.025 in (0.6 mm) #079 594 .030 in (0.8 mm) #079 595 .035 in (0.9 mm) V-Knurled Drive Roll Kits Since it accepts and uses the 0.023 drive rolls it will use 0.023 wire which is good down to 22 Ga sheetmetal. |
I've found a miller 211and 210 the difference is 300 dollars
fellas: if it counts for anything I managed to do all my patch panels and a large portion of the floor with a hobart handler 175 mig welder with gas.And i managed to teach myself to mig weld with it also. I do wish it was a Hobart handler 125. it would have been nice to have a bit lower heat setting. Most people that have seen my welding think it looks pretty good. Patience and take your time young grasshopper,you can do it. Just say'in
1970 3/4 ton long box GMC !968 C10 short stepside (Papa's Old Lorry) 2006 2500 HD Silverado Duramax/Alison |
I like the small Lincoln line. Currently have a Lincoln 140 with a gas kit. It works very well for most projects that I have tackled. This includes building roll cages and welding sheet metal.
![]() Join Date: Jul 2013
I have a Miller 140 Auto-set and a 211 Auto-set. The 140 is the one I use on sheet metal. It's just easier to use the 140 for light stuff and the 211 for general heavy welding.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
#15 | |||
"I ain't nobody, dork."
Gary
#16 |
Thanks everyone for the help
#17 |
I know if mine crapped out I would look for something besides the kind I have now I paid 3200 for mine in 1988 wouldn't that be like 8000 dollars in todays money? I am sure the ch is leaps ahaed of what my was but it still welds and I have only had to have it worked on once I did replace the liner and gun with a flex one if you don't have the swans neck look into them their the bees knees.
#18 | |
#19 |
But I also paid like $2000 for my plasma cutter that never worked right and the $750 avortec I replaced it with is ten times better.
#20 |
Looking at a miller 140
#21 |
10/30/19
#22 |
Hobart is owned by Miller, I have a Hobart 140 that will weld most things you'll come into contact with. It's a nice welder and much cheaper than a Miller. I got mine used with a cabinet, 2 gloves, and few things of wire for like $250. Plus another $120 for a bottle of 75/25 co2/argon. Been welding all kinds of stuff including my patch panels with great results. And it's only a 110v which is nice unless you have access to 220v.
