champion radiator/Steam port line
Swapping a 5.3 into my 72 c10. I'm using a champion 3 row radiator, can i run my steam vent line to the heater port on my radiator? If not should I just run a tee and tee it into my top radiator hose?
![]() ![]() Join Date: May 2015
Re: champion radiator/Steam port line
I drilled a tapped a hole in my water pump on the boss by the top hose and plumbed it in there. But I've seen them ran like you are talking about to.
The Older Generation
I used the heater outlet on my stock radiator. Actually that is an ideal place for it because it is above the coolant level. LockDoc
I also ran my steam line to the heater port on the rad. Used plumbing adapters from Lowes to connect the 1/4" line to the 3/4" port.
Thanks for the help guys, got a barb fitting for free from the local parts store.
