12-09-2015, 12:53 PM | #1 |
305 V6 Fuel pump best option? PSI
Looking to redo my fuel lines and add a new fuel pump.
Last ol'timer that saw that setup said it was too much? Said it was just dumping fuel and causing the backfire via carb issue. I think its tuned wrong still... E8012S by airtex is what is in there. Any recommendations for a smoother setup? PSI reg inline or meter? Thanks SK1
1962 GMC LWB 305v6 3spd w/OD |
12-09-2015, 03:33 PM | #2 |
Re: 305 V6 Fuel pump best option? PSI
I used this one mounted close to the fuel tank; 4-6 psi. It's kinda loud but you know it's working. Use an oil pressure cut-off switch or an inertia switch as well.
http://www.autozone.com/fuel-systems...?checkfit=true Amazon.com: Carter P4070 Electric Fuel Pump:...
MusicMan70 1961 GMC Suburban Last edited by MusicMan70; 12-09-2015 at 03:52 PM. |
12-09-2015, 06:07 PM | #3 |
The problem I see here if where the pump is mounted. You don't want electric pumps so close to the carb. They like to Push not Pull and you stand a higher chance burning it out where it sits. I'd mount it under the cab on the frame. Mounted mine there and just cut the original line a bit shorter and used rubber fuel line to fill the gap. Makes the pump work alot less.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
12-09-2015, 06:14 PM | #4 | ||
"I ain't nobody, dork."
I'd like to know what Holley carb is on it.
Gary
12-11-2015, 08:51 PM | #5 |
I'd guess he has the Holley 500 upgrade and the recommended fuel pressure is 5-7 psi.
MusicMan70 1961 GMC Suburban |
12-12-2015, 10:03 AM | #6 | |
Is a regulator worth it? Or just a fuel pressure gauge?
12-12-2015, 11:54 AM | #7 | ||
A gauge will only tell you how much PSI the pump is pushing. The regulator will hold whatever PSI you need. For a Holley... no more than about 6.5 psi.
Gary
