Old 01-14-2016, 01:06 PM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
Computer mount pictures
Let see what you got. I built a mount for mine and now I am trying to decide where I want to mount it.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 01-14-2016, 11:00 PM   #2
Aruba1
Re: Computer mount pictures
Subscribed.
Can you post a pic of your mount? I am also trying to figure where to mount mine.
Aruba1 is offline   Reply With Quote
Old 01-15-2016, 10:42 AM   #3
softballnrd27
I will get a picture today when I get home.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 01-15-2016, 10:56 AM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Computer mount pictures
Do a site search, there are several of these threads already with pictures.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-16-2016, 12:10 AM   #5
softballnrd27
I did and got a bunch of engine mount threads.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 01-16-2016, 12:11 AM   #6
softballnrd27
Here are the pics of the mount I built now I just need to figure out where in the cab I am going to mount it.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 01-16-2016, 09:37 AM   #7
65standard
65standard's Avatar
I'm mounting the LSx computer in the same spot as the original 1985 ECU under the dash top. Using the same hole in the firewall for the harness to pass thru.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 01-16-2016, 10:46 AM   #8
Andy4639
Old member
Andy4639's Avatar
Here are some links.
http://67-72chevytrucks.com/vboard/s...d.php?t=622555
http://67-72chevytrucks.com/vboard/s...d.php?t=401254
Old 01-16-2016, 02:38 PM   #9
nsb29
nsb29's Avatar
no pic but its going under the seat passenger side
nsb29 is offline   Reply With Quote
Old 01-20-2016, 01:00 AM   #10
izzy_Britton
izzy_Britton's Avatar
sorry for the hijack:
HOW are you lengthening the wire harness to reach all the way under the seat? snip solder and heat shrink? any advice would be great.
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
Old 01-20-2016, 11:38 AM   #11
nsb29
nsb29's Avatar
lay it out on a bench run your new or lengthened wiring in a loop and back to your ECM that way you cut and splice one wire at a time and a lot of patience if you PM me your cell I can send you pic Doug
Old 01-18-2016, 01:43 AM   #12
softballnrd27
Here is what I have so far, I'm still trying to figure out where I'm going to mount it under the dash.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 01-18-2016, 03:30 AM   #13
Curtb1971
Curtb1971's Avatar
Not sure if your application will work but hey might be useful to someone. Had to build a bracket for the DBW pedal so knocked out two birds with one bracket. Kept the throttle cable hole for the mechanical gauge oil line to pass through but filled the washer lines and rear harness holes. Made the plate out of 1/8" steel with a brake in it on the drivers side. Used the original gas pedal bolts and a small 90 degree brace screwed to the cab reinforcement bump out for support.
Trans controller. Took 1/4" 20 1 1/4" all thread and welded 1 1/4" fender washers to the end then ground flat to make a stud. I took these and used 3m panel bonding adhesive to glue them directly to the firewall after grinding the paint to bare metal. Did this to eliminate putting screws/hole through the firewall
Also glued some studs for the relays on the back side of the cowl gutter.
Curtb1971 is offline   Reply With Quote
Old 01-18-2016, 10:13 AM   #14
solidaxel
solidaxel's Avatar
Good location for the controllers, where did you get the harness?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-18-2016, 02:35 PM   #15
Curtb1971
Curtb1971's Avatar
The wiring Harness is from Howell Industries.
Old 01-18-2016, 09:21 PM   #16
GMC-YA68
GMC-YA68's Avatar
I saw where someone here mounted it inside the glove box and it looked pretty clean. Right now mine is on the pass side floor board up high along with my fuses /relays but I want to move it to the glove box once I put carpet in.
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 01-19-2016, 02:51 PM   #17
fast70swb
Curtb1971
What gas pedal is that from and what it work with a 2006 lq4 computer
fast70swb is offline   Reply With Quote
Old 01-19-2016, 03:43 PM   #18
'68 Newtricks
'68 Newtricks's Avatar
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 01-19-2016, 03:56 PM   #19
Curtb1971
Curtb1971's Avatar
Originally Posted by fast70swb View Post
Curtb1971
This is it from Pace Performance, not sure if it will work or not as I had to swap two wires around for a 2009 computer. I think if the connector is the same it should work, but again can't be positive.
Old 01-19-2016, 05:11 PM   #20
fast70swb
Thank you I will check it out. I'm at the computer mounting and pedal install test fitting part of my build
Old 03-02-2016, 10:31 PM   #21
Dustytrix
Great job LS64C10.
Dustytrix is offline   Reply With Quote
Old 03-02-2016, 11:47 PM   #22
truckdude239
truckdude239's Avatar
I used an 2003 zr2 s10 computer mount boltex to fendor wheel
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 03-03-2016, 01:32 AM   #23
izzy_Britton
Spaghetti much? wow!
Old 03-03-2016, 02:06 AM   #24
foamypirate
foamypirate's Avatar
This comment adds nothing to the conversation. He is probably in the middle of the install...
foamypirate is offline   Reply With Quote
Old 03-07-2016, 12:54 AM   #25
izzy_Britton
I was not trying to be condescending. I was just thinking out loud. the wiring is the one and only thing i dread about my swap. I still havent made up my mind 100% where i am going to mount mine. planning behind glove box but as i said, dread the spaghetti i am gonna need to deal with.
