Old 02-08-2016, 02:25 PM   #1
KenAdams
KenAdams's Avatar
1966 C10 Daily Driver
Just sold my previous daily driver (I work from home and only drove 250 miles last year). Here is the chronicle of my next daily driver build. The current plan is to build a reliable daily driver and something I can have fun on the track with.
I bought the truck out of Vegas and brought it back to Richmond. It's a long bed step side originally sold as a GSA.
I don't plan on doing any exterior work, I think I actually like it. My current plans are:
replace front of inner rockers, new outer rockers
-new ls3/t56
-coil over
-disk brakes
-rebuild rear
-shorten frame & bed
Start:
Current State (09/12/2018):
KenAdams is offline   Reply With Quote
Old 02-08-2016, 02:30 PM   #2
KenAdams
KenAdams's Avatar
Re: 1968 C10 Daily Driver
Started this late so a couple days work lumped into one:
Also to be posted for sale, parts, or scrap in a minute:
Old 02-21-2016, 05:39 PM   #3
KenAdams
KenAdams's Avatar
Re: 1966 C10 Daily Driver
Stripped the cab and started on the drivers side rockers.
Old 09-11-2016, 05:21 PM   #4
KenAdams
KenAdams's Avatar
Was finally able to get back to work, almost finished with the driver's side rockers, patched the high hump shifter hole, and have moved on to the passenger side.
Old 09-12-2016, 02:37 AM   #5
Grizz1963
Grizz1963's Avatar
Welcome and WoW !!
Loads of work.
List will be done in quick time.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 10-16-2016, 09:45 AM   #6
KenAdams
KenAdams's Avatar
Almost finished with the passenger side inner rockers and floor. Just have to finish a small patch and the bottom of the door pillar. One thing I have to remember is I will never order "Goodmark" panels again. They were super cheap on Summit but required a lot of fitting. I had to make a cut on the front of both the driver's side and passenger side inner rocker and add a pie shape piece so it would fit correctly.
Old 10-16-2016, 10:41 AM   #7
RDrancher
RDrancher's Avatar
Nice work so far. I'm in for the ride.
Romans 10:9 - The Truth
RDrancher is offline   Reply With Quote
Old 10-18-2016, 10:12 AM   #8
KenAdams
KenAdams's Avatar
Posted else where, but thought I would add it here too. I have determined I am going to shorten the bed by just removing 20 inches out of the middle of it. I've seen other guys shorten their fleet sides by removing 12 inches out of the front and 8 inches out of the rear. Since it's a stepside I am just going to remove 20 inches out of the middle. and move the bolt holes for the fenders. We'll see how it turns out.
**August 6, 2018 UPDATE, 12" out of the middle of the frame and 8" off the rear will change the frame from a longbed 127" to a shortbed 115" wheel base. To shorten the bed 12" out of the middle does work, but the correct repositioning of the bolts is moving half 14.5" forward, and half 5.5" to the rear. The stepside step is 14.5" shorter then the longbed step. See page 5.***
Old 10-18-2016, 11:48 AM   #9
KenAdams
KenAdams's Avatar
Ugh. I removed the rear and started on disassembly yesterday. Just ordered axels, gears, & posi from Jegs... Hopefully I picked right. Plan is to sandblast and paint the dif this week and then start reassembling next week.
$275.00 Moser Axels A3065GMT5 1965-69 GM Truck Spline 30 A3065GMT5
$560.00 Moser Posi 12 Bolt-4 series-- 30 Spline E12T304
$164.95 Richmond Gear 12BT373 Series 4 836-12BT373
$100.00 Moser 13010 Yoke PY110
$110.00 Moser Rebuild Kit R12BT
$40.00 Moser Axle Bearings & Seals 9559
$9.99 Jegs Pinion Shims 555-612051
$160.00 Moser Rear Cover
$17.50 Moser 1/2''-20 x 1-1/2'' .530'' KnurlWheel Studs 8138
Need to order rear brakes, planned on:
$794.99 Wilwood Rear Brakes w/ Parking Brake 140-12569-DR (D154)
But might shop around on price and see if I can get a deal with the fronts.
Old 10-18-2016, 11:58 AM   #10
KenAdams
KenAdams's Avatar
Just ordered the ride Ridetech Level 2 Coil over kit from MCB Matt! He has some killer prices!
At this rate I might actually have the truck on the road during Christmas... Might switch from 1 to 2 weeks off at Christmas so I can finish this up!
Old 10-22-2016, 08:02 PM   #11
KenAdams
KenAdams's Avatar
Pulled off the cab, and put in a full day of burning through cut-off wheels. I have another lwb frame that I already shortened, but I think I am going to shorten this frame as well to keep it "numbers matching." I am sure no one else would even know or care but somehow it makes me feel warm inside knowing it's all the same truck. The plan is to get the front off tomorrow and then shorten it over the next week and then sandblast and paint. I am actually at a dilemma... I had planned on powder coating it, but think I might paint it depending on how good the rear looks after the final coat of paint.
Old 10-22-2016, 09:27 PM   #12
northern 85
northern 85's Avatar
Wow im in on this one!!!
northern 85 is offline   Reply With Quote
Old 10-22-2016, 11:16 PM   #13
Joe Pass
Joe Pass's Avatar
Nice work....
Joe Pass is offline   Reply With Quote
Old 10-23-2016, 12:54 AM   #14
Captainfab
60-66 Nut
You're moving right along.
Just a FYI, I make 3 different rear disc brackets for the 5x5 wheel stud pattern. Links to the for sale threads in my sig line \/ \/ \/
I also make a booster bracket with the hydraulic clutch conversion, which you will need for your T56.
http://www.67-72chevytrucks.com/vboa...d.php?t=651200
Old 10-23-2016, 09:41 AM   #15
KenAdams
KenAdams's Avatar
Thanks Captain. I've known I need to order a bunch from you for a while, I'm still trying to figure out what I am going to do with the rear brakes before I place and order. My main problem is I have to have a parking brake. I know I don't have to run Wilwoods, but all the cool kids are doing it and it solves my parking brake problem.
Old 10-23-2016, 03:23 PM   #16
KenAdams
KenAdams's Avatar
Finished stripping the frame today of everything except for the: front, trailing arm, and original transmission cross member. I'm going to leave them till I finish shortening the frame then I will bust the final rivets. I took off the upper control arm mounts off of the front cross member today as well. That was a task especially since I couldn't remember what happened to my air hammer. I remember using it in 2012, so who knows where it is now?
The short term plan is to cut and weld up the frame and cut the frame Ridetech kit which is susposed to be here tuesday this week. Then sandblast the frame the beginning of next week and paint if it is warm enough. I've been putting off buying a heater for the garage, maybe it's time I pull the trigger.
Old 10-23-2016, 03:37 PM   #17
KenAdams
KenAdams's Avatar
Thought I would post the setup for the frame shortening. Fingers crossed I can get it cut up and welded on Wednesday.
12 inches out of the center of the frame, 8 out of the rear, then I am going to take a single 20" cut out of the long bed stepside.
Old 10-25-2016, 06:18 PM   #18
northern 85
Very very nice!!!!
Old 10-25-2016, 07:43 PM   #19
KenAdams
KenAdams's Avatar
Getting started... No turning back now.
Old 10-27-2016, 05:34 PM   #20
KenAdams
KenAdams's Avatar
Got it cut, before heading out for the weekend. Probably no progress this next week, busy with some work items.
Old 10-29-2016, 08:04 AM   #21
northern 85
Looks really good!!!
Old 10-29-2016, 09:16 PM   #22
slowGN
slowGN's Avatar
Looking good. Hope to see it riding around on the road soon.
slowGN is offline   Reply With Quote
Old 10-30-2016, 08:33 AM   #23
KenAdams
KenAdams's Avatar
Thanks! I'm hoping for June.
Old 10-31-2016, 03:20 PM   #24
KenAdams
KenAdams's Avatar
Got back from a wedding out of town yesterday. And measured out the entire rear end housing. It's not perfect, but it's darn near close.
I started to assemble the rear today and had an odd pattern. It was too far to the heel on the drive side and to much toe on the coast. It took me a minute to realized what had happened; I forgot to put the pinion shims in. The real bad part was I was out of marking compound. After I took these pics. I ripped it apart and put the shims in and it looked okay. I ordered some more marking compound and will do a final assembly later this week. Here is pics of a .025" too shallow pinion:
Old 10-31-2016, 04:52 PM   #25
KenAdams
KenAdams's Avatar
Got my "fish plates" in. I think I am going to hole saw out an 1 1/8" hole in the middle for additional strength. Hopefully I can get this frame finished up. I want to start assembling it!
