03-05-2016, 06:46 PM | #1 |
72 C/10 fuel tank relocation
I'm about to start a complete rebuild with a LS1 6.0. I am planning on using a tank from LMC. I would like to install an in tank fuel pump. Any suggestions on make and model?
03-10-2016, 10:10 AM | #2 |
Re: 72 C/10 fuel tank relocation
No advice. Must be a really dumb question!
03-10-2016, 04:08 PM | #3 |
i am a little slow what is LMC? Measure the space where you plan on putting the fuel tank max lingth x max with x mas dept .Also find the specks on the fuel presure that is needed to run the ls motor. it may be posible that something that came with that motor had a tank that will fit. do your research.
http://www.cardomain.com/id/jmcleek |
03-10-2016, 04:23 PM | #4 |
motor exploder
Being in the wrong section of the forum doesn't help either.
Try the LSX swap section in the 'Engine & Drivetrain' sub forum, or the main 67-72 Message Board, or research the FAQ section. This might help with your 'really dumb question'. http://67-72chevytrucks.com/vboard/s...d.php?t=457134 And this might be a better source for the tank if you're switching it from behind the seat - their quality is excellent and Dave is great to work with. http://www.fueltankparts.com/67-72-e...-bed-fill.html
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! Last edited by BossHogg69; 03-10-2016 at 04:30 PM. |
03-10-2016, 04:24 PM | #5 |
I would look at Boyd welding's tanks. I've got one with an in tank fuel pump. Excellent quality. And they make them specifically for our trucks. You can get them here http://www.azproperformance.com/Boyd-Welding.html
03-10-2016, 04:27 PM | #6 |
Thanks BossHog69. Wrong section? That won't happen again cause I'm out of here!
03-10-2016, 04:38 PM | #7 |
