03-19-2016, 12:35 AM | #1 |
Door locks
71 Burb. The doors (all 3) will lock when they're open, but not when they're closed. I have had the panels off and can't see anything obvious. Doesn't matter if the windows are up or down. Don't know if new latches and/or strike plates will make a difference.
Any suggestions will be appreciated. 57 3100 71 C10 71 GMC Suburban 98 GMC 1500 |
03-19-2016, 12:59 PM | #2 |
Re: Door locks
Have you tried any lube on the lock prawl part of the latch? My third door lock is really sticky from not being used.
*Edit* Try to avoid using WD-40, it tends to gather dirt. You want to use something that doesn't collect dirt, or at the very least a penetrating oil.
1996 Chevrolet K1500 (daily runner) 1969 Chevrolet Suburban K20 "Solomon Grundy" *Click for build thread!* Last edited by ChopsawSurgeon; 03-19-2016 at 01:06 PM. |
03-19-2016, 03:09 PM | #3 |
Re: Door locks
I think I recently used white grease on them, but not PB Blaster type stuff. I will try that. The pawls,the spur rowel looking part, seems to move ok. It's just weird that all 3 doors have the same problem. The PO removed the vents in front and put in electric windows and set up the doors for PDL. I thought that might be the issue, but the back door is OEM. Thanks for the tip.
03-19-2016, 05:21 PM | #4 |
Re: Door locks
you're not talking about locking the door then closing it and not staying locked are you?
1968 Chevy C-10 Suburban - 350/350 1969 Chevy C-10 Panel Delivery - 454/400 1972 GMC K1500 Jimmy - 350/350/np205 1978 Chevy Corvette Silver 25th Anniversary reddit.com/r/chevyc10 <-Join it! |
03-19-2016, 05:48 PM | #5 |
Re: Door locks
No. I know better than that. If I push any of the 3 buttons down when that door is open, it goes down all the way and locks. The button does not go down fully when door is closed therefore not locking.Using the key on either front door will not lock them either when door is closed but will when it's open. My theory is something is binding when the door closes but I can't see or figure out what. And why in blazes is it happening to all of them? They worked, though not good,when I bought it about 18 months ago. I didn't do anything to any of the doors that I recall.
03-19-2016, 06:59 PM | #6 |
Re: Door locks
You might be right on the binding part, only other thing i can think of is that the doors weren't adjusted properly after the window conversion. They could be adjusted where they are latched, but only just enough and the latch is in limbo between the two and not allowing the lock to slide.
1996 Chevrolet K1500 (daily runner) 1969 Chevrolet Suburban K20 "Solomon Grundy" *Click for build thread!* |
04-13-2016, 12:32 PM | #7 |
Re: Door locks
04-13-2016, 09:38 PM | #8 |
The Older Generation
Re: Door locks
Because '67-'72 Chevy trucks will not do that. It was a feature so that you couldn't lock your keys in the truck. You have to lock them with the key, from the outside.....
LockDoc
04-14-2016, 12:35 AM | #9 |
Re: Door locks
Today I looked an echlin dlk11 lock set listed for our trucks and it turns both ways (right and left), as does the set I have at the house so.. if I take things apart I may as well put new cylinders in. I'll just have a different key for the doors than the lift gate and ignition. No big deal Sorry to steal your thread reichdav. thanks for the help!
04-14-2016, 05:19 PM | #10 | |
Re: Door locks
No problem. New might be the way to go. LockDoc
03-19-2016, 07:29 PM | #11 |
Equal opportunity joke ofender
Re: Door locks
If there is a lot of pressure on the latch with the doors shut it will cause you not to be able to lock them. One of my old trucks I had to push up on the door handle to lift the door(while shut) and turn the key at the same time to get it to lock. My case was due to worn hinge pins.
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
03-20-2016, 01:18 AM | #12 |
Re: Door locks
I have with the help of a friend adjusted the 3 doors as alignment was poor when I got it. The binding on the latches makes a lot of sense. The latches and strike plates appear to be OEM and who knows how much wear they've seen. I will try to make adjustments on them without screwing up the opening and closing. If that doesn't work, I might have to spring for new ones. Thanks.
03-20-2016, 10:48 PM | #13 |
Re: Door locks
Mark around the strikers with a fine felt tip pen and move them out 1/16" at a time until the locks start working. Make sure they don't drop down any..... LockDoc
03-22-2016, 09:01 AM | #14 |
Re: Door locks
Will do. Thanks.
04-06-2016, 08:31 PM | #15 |
Re: Door locks
My 72 blazer won't lock from the outside with a key on the drivers side but will unlock. On the passenger side it locks from the outside but won't unlock with the key. So to lock it up I have to climb out the passenger side after I have locked the drivers form inside and lock passenger side from the outside. To get back in I have to use the key in the drivers side,any ideas?
04-07-2016, 12:38 AM | #16 |
Re: Door locks
i guess i put this question in the wrong spot . didn't notice I'm asking blazer stuff in the burb and panel section..oops! I've owned 6 c10's and never had door locks concerns
04-07-2016, 01:27 AM | #17 | |
Re: Door locks
Let me know if that works or not. LockDoc
04-08-2016, 12:09 AM | #18 | |
Re: Door locks
04-10-2016, 09:35 PM | #19 | |
Re: Door locks
LockDoc
04-11-2016, 12:08 AM | #20 |
Re: Door locks
My passenger door was the same way. Just bought new latch assembly, now works super smooth. Worth the money. Also had Leon,"LockDoc" redo all the lock cylinders for me. Super fast service, all keys work butter smooth, and a great price.
04-11-2016, 11:56 PM | #21 |
Re: Door locks
My blazer just rolled over 95k miles and I have been trying to keep from changing to many oe parts to aftermarket It's only an inconvenience not broken. I have an extra set of locks if I had to. Thanks guys.
05-17-2016, 12:20 AM | #22 |
Re: Door locks
None of mine will lock from the outside with a key unless I grab the handle and push the door inward. Its too tight on the weather stripping. It will just bind otherwise. None will unlock from the inside unless I grab the inside door handle and wiggle it a ton.......same deal I guess, too tight on the weather stripping. I plan on fixing it when I put in new weather stripping , but for now.......less water inside is a better deal.
05-17-2016, 12:39 AM | #23 |
Re: Door locks
the door latch is worn out nothing to do with the lock i went threw this last year with my truck there is a post about it on here somewhere. the little sprocket thing that is on the latch wears and puts negitive pressure on the lock that is why some can get the lock to work when they press on the door cause it take the pressure off the lock.
01-27-2017, 11:28 AM | #24 |
Re: Door locks
They're probably still building Rome also. I know I been building my 67 Stepside for 20 years this September!
01-28-2017, 11:53 PM | #25 |
Re: Door locks
I say building , I been driving it when I'm not working on some part of trying to improve it in some way or just keep it going.
