!972 K20 with 5.9 Cummins Diesel and factory tach cluster
Hi guys,
I am a first time poster, but have searched and found most info I needed by using search function. I am the 3rd or 4th owner of a 1972 Chevy K20 pickup that has been modified and chopped up by all previous owners. I purchased the truck with the expressed purpose of putting a Cummins 12 Valve diesel in it. Speedo, oil pressure, water temp, and voltmeter all work with the Cummins, now I am looking to tackle the tach. It is a factory tach, and looks original. It worked with the V8 that I pulled, but diesels don't have the traditional coil to hook up the tach wiring. My question is: Can I use a tach sending unit that is available from Summit and mount it to read off the crank shaft? I know the tach has a ground, 12v, and wire for a coil. Not sure if this tach needs a special power or signal input |
Re: !972 K20 with 5.9 Cummins Diesel and factory tach cluster
Would also like to use a factory tach with my cummins. Anyone know what we need? I see your in Minnesota also !
Matt
1971 k5 blazer 80k mike survivor 1972 3/4 ton 4wd Cummins 12v 1967 swb 2wd 427bbc 1968 4wd shortbox 1971 Cheyenne swb k10 unrestored 1971 Cheyenne super 40k 402bb survivor 1967 Chevy k10 (first truck) 1968 L78 camaro survivor 18k miles 1969 z28 survivor 60k miles 1969 z28 survivor 39k miles 1969 z28 rs survivor 80k miles |
SWB 4x4 Collector
![]() Join Date: Jun 2001
You could use the factory diesel tach dash....that I know can be hooked to the Cummins.
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
