04-06-2016, 12:35 AM | #1 |
Rearend and trans lube change Viking 59
Just checking a few things off my list to getting roadworthy.....
Today I open rear end and change fluids on both rear end a trans with 75,000 + miles and been sitting for yrs.. I was happy to see the rear end oil/lube full and no suprises . BEFORE . cleaned painted cover And made a gasket . . . . . The trans fluid change . . The rear took 2.5 gal the Trans was just under 1 gal . .....................................Sp . . . . . . . .. .
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
04-06-2016, 04:56 PM | #2 |
Re: Rearend and trans lube change Viking 59
OH MY! Those are some serious bearing caps, makes one of my old Dana 60's look inadequate. I couldn't imagine how badly that trans or diff oil smelled.
55.1 GMC Suburban Hydramatic |
04-07-2016, 01:15 PM | #3 |
that is a serious stack o springs on that viking
is that a posi rearend? looks like room for the clutch pack
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
04-07-2016, 03:05 PM | #4 |
Hollister Road Co.
I'm surprised you didn't have a bunch of flake rust inside after all those years, That look really clean
04-07-2016, 09:35 PM | #5 |
I wish and wonder why it wasn't but it's a
non posi... without the Duels I almost got stuck surprising no rust not even the inside of the tin cover with no paint on it no rust.? and the rear end oil was full and did not smell that bad Only thing I can figure is the gear oil did it's job by coating everything inside that big ol rear and preserved it . . . funny everthing above ground rusty as all get out... bellow ground no rust go figure.? . As found 06-13-2014 . . . ..
04-07-2016, 10:57 PM | #6 |
Hollister Road Co.
I don't know of any two speed axles that were POSI back then. it was hard enough getting the planetary reduction gears in the carrier housing let alone a POSI unit
04-08-2016, 03:21 PM | #7 |
doh! now i see the vacuum lines to the rearend
i had a 56 chevy schoolbus/camper that had the vacuum 2 speed, luckily i never had to go into it
04-08-2016, 10:39 PM | #8 |
Today was a good day.!
longest trip to date in the truck Well did some house cleaning today (wiring) took it out to get fuel down to 9% in a 30 gal tank.? to the local propane store (only one) when i got there they were closed no reason probably because it was sunny and friday.? It was a grueling 6 miles round trip and when I say grueling. I'm mean I think I bruised a kidney.... The tires felt like there were more square then round it rattle so hard knocked the cap off the battery it was a tough go I hit 35 in fourth gear so I tried my hand is two speed shifting I failed miserably ....... Did get the rear to shift twice I think the magic is get up to speeds push in clutch let the engine idle (to build vacuum) while rolling hard hit the two speed axle button let out the clutch give some more fuel and hope for the best I'm 2 out of 7 tries I'll have to study that utube video some more . sorry no pictures of truck . but you ol duffers might appreciate a model 77 . .
04-08-2016, 11:27 PM | #9 |
. the sticker I tried to remove off the dash before restore mode I'm so confused.???
