06-02-2016, 07:39 PM | #1 |
Spring perches ?
Okay, so I am going to be using a cpp rear shock mount crossmember the question is when I removed the oem crossmember it also removed what I would refer to as the upper spring perches, which I have added a picture of. Do I have to have these on there ? Or can I bolt my springs directly to the frame ? All the pictures cpp shows have the cnotch kit installed which seems to replace this piece. I dont see any issue bolting them to the frame other than it may cause abnormal wear. Thanks for any help
06-03-2016, 03:26 AM | #2 |
Re: Spring perches ?
No one knows ?
06-03-2016, 06:45 AM | #3 |
I would use them because it is a reinforcing plate as well.
06-03-2016, 10:37 AM | #4 |
Well if I do a cnotch kit which is made of 1/4" steel that should replace the need for this piece then correct ? Thanks for your response
