09-26-2016, 11:13 PM | #1 |
Intake to Booster Hose
What hose (part number or size) is required to run from the truck intake 2003 4.8L to the vacuum booster (CPP)?
Is there a specific hose that fits nicely or will a generic size be required? I don't have the factory hose of the donor vehicle. |
10-04-2016, 11:57 AM | #2 |
Re: Intake to Booster Hose
When I was doing my swap (LQ4 into 87 Suburban) My nipple on the motor was a little different in size than the nipple on my brake booster. I had to get two pieces of hose and a brass barbed adapter from Home Depot to make it work.
I'm sorry I can't remember what size the hoses or the adapter was.
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824 |
10-17-2016, 10:46 PM | #3 |
Garage wrench
I can't remember the part number but I called a local chevy dealer and had them order me the correct part for an '06 Silverado with a V8. Worked perfectly on my '85 Suburban with a 5.3 from an '05 Avalanche. Also had them order me the correct nipple too, I think it was less than $30 for both pieces. Worth the money and way better looking than piecing something together IMO
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
10-18-2016, 08:00 AM | #4 |
I had the same problem. Ended up using 2002 gmc Yukon Denali hose and fitting. The 2003 Z71 4x4 was to small
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
