10-04-2016, 10:27 AM | #1 |
Putting bed back on after tank relocation
Relocated my gas tank on my 68 c10 to underneath the bed. When putting the bed back on I can not get the nut on the 2 bolts towards the back of the truck that are above the tank, I cant get my hand or wrench in that location. Any special way of doing this? The remaining six bolts I had no problem with, just the 2 over the new gas tank location.
10-04-2016, 11:10 AM | #2 |
Re: Putting bed back on after tank relocation
maybe drill a hole in the bottom of the frame rail to gain access from there. with socket and extension. maybe one guy on top to push down on the carriage bolt while you tighten from bottom.
10-04-2016, 08:37 PM | #3 |
Did you trim the one crossmember that goes a crossed the top of the tank? Could that be what is throwing things off?
10-04-2016, 09:07 PM | #4 |
Like he said, did you trim the crossmember to clear the tank? I just put the bed on mine and don't recall having this issue.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
10-04-2016, 09:17 PM | #5 |
I welded nuts to the bottom of the cross bar. I then took a thin carborundum disc and slotted the carriage bolt head. Then ground off the square part of the shank so the bolts could turn and be installed from the top. Used a large screwdriver to install the 2 bolts. My slats and bolts are polished stainless steel, but same technique would work for any hardware finish. Nobody has noticed the slots.
Russ
RC |
10-04-2016, 09:44 PM | #6 |
Buy a longer careiage bolt and put nut on bottom side of frame rail
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
