10-19-2016, 11:08 AM | #1 |
Booster and Proportioning valve
Where is the best place to get anew booster and proportioning valve? This is for my 70 C20 3/4 ton
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
10-19-2016, 08:32 PM | #2 |
Who Changed This?
Re: Booster and Proportioning valve
You can get an unloaded booster from NAPA. That's where I got mine.
Alco, https://www.google.com/search?q=70+c...utf-8&oe=utf-8
10-19-2016, 09:46 PM | #3 |
For my 1970 3/4 2500 I bought one from www.brakeboosters.com
I forget where I got the prop valve, but I know they're not cheap (like $250 from memory).
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
10-19-2016, 11:45 PM | #4 |
10-20-2016, 12:33 AM | #5 |
20' Daredevil (Ret)
^^ What he said. There was no proportioning valve with your drum/drum system, it came with a distribution block. Similar appearance but different inside.....
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
10-20-2016, 03:21 PM | #6 |
Correct, mine is drum drum, so I need the distribution block. Do you know where to get that at?
10-20-2016, 04:52 PM | #7 | |
http://www.inlinetube.com/_p/prd14/2...on-block-pr112 I thought they also sold the bracket, but I don't see it on their website. Might be worth a call though. Those they have for the cars don't look right. Last edited by FirstOwner69; 10-20-2016 at 04:57 PM. |
10-20-2016, 05:09 PM | #8 |
I should point out, as other's have noticed, that mine is a '72 front disc conversion, it also had drums and no prop valve originally. Sorry, I completely forgot it wasn't original to my truck!
10-20-2016, 05:21 PM | #9 |
Save your money use piratejack.net call them and describe what you need or what problem your having and they'll take care of you ! Great prices and great custom service .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
10-20-2016, 06:02 PM | #10 |
What are you suggesting, that he rebuild his own booster? Just opening one requires an arbor press and courage.... and it's not the safest thing in the world either, there's a ton of potential energy in there. Enough that it can fly all the way across your shop and hit your Camaro.
10-20-2016, 06:53 PM | #11 | |||
"I ain't nobody, dork."
That's not what he is suggesting at all... Gary
10-20-2016, 07:18 PM | #12 | |
10-20-2016, 06:20 PM | #13 |
another brake question. Is there a difference in the lines ( like dia) between a 1/2 ton and 3/4 ton? Or do they all use the same size lines?
