Stock blazer height
I have a 1970 blazer with a lift and not sure what the size is. Hope to get stock height measurements at front and back wheel wells. Center point. Then I can measure and find if I have a 4 or 6 inch lift. My springs have been reached at some point.
1970 Chevy blazer with 6.0 ls conversion. |
Re: Stock blazer height
Welcome to the board. Post a pic of your truck, we can get a good idea of what height lift you have. Also were just the front springs re-arched?, If the rear has a lift block, just measure that, then you'll know what size lift you have. My '70 Blazer has a four inch lift so can't help with measurements.
Carpe manana
![]() ![]() Join Date: Dec 2010
A 72 MY Blazer 4wd is 68.5" from ground to the top of the windshield frame per factory specs. Don't have specs for 70 but probably close I'd guess.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Both front and rear springs a arched, no blocks. I am running 33" tires. Getting ready to 4 link the front suspension.
