12-20-2016, 05:20 PM | #1 |
Exhaust Question?
Hello to all. I recently had a completely new exhaust system put on with long tube headers and I'm gonna be going back to the ram horns because it's to loud for my taste. As you can see in the photo there's is only about a foot of pipe after the ram horns. My question is would it be OK to drive with that little of pipe for about 2 miles?
12-20-2016, 05:48 PM | #2 |
Re: Exhaust Question?
Heck yes! And with your foot in the gas as much as possible for those 2 miles.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
12-20-2016, 10:54 PM | #3 |
Born Psycho
you can drive it with no worries.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
12-20-2016, 11:24 PM | #4 | |
Shouldn't you be looking into getting different mufflers? |
12-21-2016, 12:45 AM | #5 |
what mufflers you running???
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
12-21-2016, 01:30 AM | #6 |
12-21-2016, 02:31 AM | #7 | |
Does you system have an "h" pipe, or some type of crossover ? |
12-21-2016, 02:38 AM | #8 |
Nope, just 2½ inch straight duals. I'll be swapping out the manifolds after Christmas so if the drone is still there then I might be going back to glass packs...
12-22-2016, 08:37 PM | #9 |
Yeah, this is your problem. I have 40's and exhaust manifolds (not my choice) and it's way too loud for me. The manifolds may.... may shave 5db or so off the volume. I'd change the mufflers before the headers.
12-21-2016, 08:53 AM | #10 |
I'd swap out mufflers before I took off headers and went back to the manifolds. Like hdff said look into a 50 series muffler or I've always loved the dynamax turbo mufflers, or the summit knock off, cheap and sound great.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
12-21-2016, 08:57 AM | #11 |
My car with iron manifolds and flowmasters drone..
change the mufflers.. |
12-21-2016, 09:42 AM | #12 |
I switched from 40s to 50s. 50’s are definitly quieter. Changing out the headers and leaving the 40s is not going to make much difference. As mentioned if you are dumping the exhaust under the truck you will get more resonant sound. You start running out of room if you want to go with a larger/quieter muffler like a 70 series. You have to get creative with pipe routing and muffler placement to accommodate a larger mufflers. I installed an H pipe, didn't like the "motor boat" sound at idle. Took it off. I guess it all depends on your cam. I also have 2-1/2 pipes, mild cam.
1970 C10 Short Stepper with 71/72 front clip. |
12-21-2016, 09:39 AM | #13 |
I have headers and unknown mufflers with dual side exit behind the tires. It is very quiet. Even at cruise, 3,000 rpm, not loud at all. I actually want louder.
Keep the headers!
1982 K10 SWB 1987 V20 - Sold - Doh! |
12-21-2016, 09:56 AM | #14 |
Your drone is coming from your Flowmasters and not your headers
______________________ www.northeastrodrun.com |
12-21-2016, 10:09 AM | #15 |
I had flowmasters on an 84 monte carlo first with an h pipe which I loved the sound. Due to a transmission swap I had to get rid of the h pipe and hate the sound of it. I would say try an h pipe first. If you dont like the sound after that try different mufflers. The manifolds will not do anything for the drone.
12-21-2016, 10:11 AM | #16 |
Before you go and do something you'll regret, read carefully. In many cases, manifolds can have a slightly louder tone than headers. Headers equal out the tones and at times, depending on how they're made, cancel out some of the mismatched tones. [If that makes any sense.]
The loud drone most likely isn't the headers, and in some ways will actually get worse with the manifolds. My suggestion is to get rid of the Flowmasters. They're notorious for drone because of the chambered design. The chambers hold in the sound and reverbs it back in forth inside the muffler. Also, in my experience, the 50 series Flowmaster are less noisy, but the ones I had droned worse inside the cab. This was probably because of the reverb effect, happening in three chambers instead of two. I suggest a non-chambered muffler like Magnaflow or Black Widow. My only complaint with Magnaflow is they're almost too quiet at idle. I've never ran a set of Black Widows, but the reviews are great, and YouTube videos prove they have an aggressive sound. Changing from headers to manifolds with the current mufflers WILL NOT make it it any more tolerable!! You will have spent money to accomplish nothing.
12-21-2016, 10:17 AM | #17 |
Or look into a set of resonators.
12-21-2016, 12:41 PM | #18 |
Get a camry to daily drive for a drone free commute
I gotta ask, are the mufflers under the cab or the bed? You know there is enough room to put a couple magnaflows under the corners of the bed to get the mufflers as far away as you can from the passenger compartment.
12-21-2016, 12:57 PM | #19 |
I also have ram horns with dual exhaust with no H-pipe. I have some generic mufflers that the muffler shop set me up with. Do you guys have any experience with adding J-pipes? They are supposedly tuned by making them a specific length and they cancel drone. From what I've read it sounds scientific. Better than H-pipe?
12-21-2016, 01:44 PM | #20 |
Here is a link to a thread with some J Pipe information. If my Burban drones after the new exhaust is installed I will be going down this road.
http://67-72chevytrucks.com/vboard/s...=680126&page=8
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
12-21-2016, 02:29 PM | #21 |
As the others have said... get rid of the Flowmasters. I like the MagnaFlow mufflers, but there are several others out there that are great. I have an 18" MagnaFlow on my daily driver and it is darn near perfect. Borla makes a great muffler, but they are somewhat expensive.
Change the mufflers first and see what that does. Then start with the other parts. |
12-21-2016, 04:35 PM | #22 |
I feel ya! Just put shortie headers and 2.5 pipes with a H and flow masters. Drone was horrible. Sounds upside was fantastic! Drone in the cab was miserable. I put the "Hymotlz Chambers" on. No effect. Changed the mufflers to stock turbos. No effect. Finally put Stock resonators on the tail pipes at the bumper!!! Presto fixed it. Flow master back on. No drone. "Hymolts Chambers" cut off. No drone. My exhaust dumps at the rear bumper. Good luck. It's gonna cost you money to figure it out
12-21-2016, 05:05 PM | #23 |
All I can say is being a noobie with exhaust. You all are great help! I just ran the truck and looking close these flow masters gotta go. I originally had 2 inch duals and glass packs(loved the sound but they were about to fall off) going out behind the tires. Now headers, 2½ inch pipe with 40s that dump right in front of the axle. I was going to finish the exhaust going out the back but I guess it's time to find some different mufflers..
12-21-2016, 04:56 PM | #24 |
I agree get rid of flowmasters and get magna flow or the knockoff thunderbolt. I have used both to replace flowmasters and they have no drone and in my opinion sound much crisper/cleaner.
12-21-2016, 05:24 PM | #25 |
Dumping before the axle isn't helping, either. Run the pipes out the back to help with the sound also.
